Ariens 920025 - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-15-2020, 03:45 PM Thread Starter
Angry Ariens 920025
I have a newer Ariens, it has not been used for two full seasons yet. I added gas recently and turned it on for the first time this year, the auger is not turning. I checked both shear pins and they appear to be fine. Any idea what else to check?
Side note, I am not super mechanically inclined, but I'd like to save myself a hundred bucks or more from calling a service guy.
TIA!
Sadie Connolly is offline
post #2 of 5 Old 01-15-2020, 03:54 PM
Thanks (Received): 149
Likes (Received): 543
If you press the Auger engage lever, then I would first make sure you feel the tension from the lever of the idler pulley moving and engaging the actual auger drive. If not, I would pull the belt cover, and check the belt, as well as the auger linkage for adjustment if indeed the belt and idler pulley are in good order.
oneacer is online now
post #3 of 5 Old 01-15-2020, 03:58 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 147
Likes (Received): 297
Oneacer beat me to it, also may be the cable doesn’t have enough tension and may need adjusting, where about are you located as one of us who are close may be able to help.
Dauntae is offline
post #4 of 5 Old 01-15-2020, 04:46 PM Thread Starter
I am in Minneapolis.
post #5 of 5 Old 01-15-2020, 05:23 PM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
Welcome to the SBF!
2019 Ariens Compact 24...
penna stogey is offline
