New Dipstick Tube on Old Tecumseh - o-ring? - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 01-18-2020, 10:10 AM Thread Starter
Thanks (Given): 16
Likes (Received): 11
I recently decided to treat my ol' 924039 to one of those newer dipsticks with the long tube. I was kinda surprised to see that the only o-ring that came with the kit is for the yellow cap. Is there supposed to be something that seals the black plastic tube to the engine block? I am referring to where I circled in the attached picture.
The old dipstick had a paper gasket that I unfortunately ripped trying to get it cleanly on the new black tube. Does the fact that the tube is plastic make it seal adequately?
My machine:
Stang is offline
post #2 of 11 Old 01-18-2020, 10:40 AM
Thanks (Received): 150
Likes (Received): 543
If I recall, those plastic dip stick tubes have an O-ring on the lower area.
I just use the normal case check/fill plug.
oneacer is offline
post #3 of 11 Old 01-18-2020, 11:53 AM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
I've done this upgrade to some older Tecumsehs when I happen to have one from a parts engine, and the tubes don't seem to have provisions for an O-ring where it meets the block.
db130 is offline
post #4 of 11 Old 01-18-2020, 12:53 PM Thread Starter
Thanks (Given): 16
Hmmm the one I have doesn't. I tried placing an adequately sized o-ring, but it seems like it would raise the tube a hair, as there doesn't seem to be a channel in which it can fit/compress.
That does seem to be the case with this one. Any problems with leaks?
My machine:
Stang is offline
post #5 of 11 Old 01-18-2020, 12:55 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
I don't know for sure but I'm guessing the engine doesn't have the machining to accept an O ring. You might be able to get one to fit.
You could always lay a small bead of silicone around the base of the tube after thoroughly cleaning it and the mating surface around the hole.
post #6 of 11 Old 01-18-2020, 01:01 PM
Thanks (Given): 16
Likes (Given): 241
None. Keep in mind that the oil sits on the bottom of the block and is splashed around by the oil flinger. It would need to defy gravity to creep up past the plastic threads. There's also the built-in flange at the bottom of the tube.
db130 is offline
post #7 of 11 Old 01-18-2020, 01:28 PM Thread Starter
Thanks (Given): 16
Makes perfect sense. I was more concerned with leakage when the machine is perpendicular in service mode, but that's not a common occurrence anyway.
My machine:
Stang is offline
post #8 of 11 Old 01-18-2020, 11:25 PM
Thanks (Given): 80
Thanks (Received): 47
Likes (Given): 277
Likes (Received): 157
I can't tell from the photo but did it come with a little bracket to attach the neck to the sheet metal on the engine shroud to prevent it from vibrating out? If not, perhaps you can fashion a "p" or "u" clip or even a hose clamp.
I see you also treated your girl to some of those newfangled shoes!
ID:	162717   Click image for larger version
rod330 is online now
post #9 of 11 Old 01-19-2020, 02:02 PM Thread Starter
Thanks (Given): 16
Sharp eye! Actually, I took that picture right before I realized that I forgot to install the clip. I have it on now. It's a pretty tight fit - it bites so hard into it that it was impossible not to scratch the tube when installing it. No way it's vibrating loose now.
I ran the machine for 45 minutes last night and noticed no oil leaks at the block, so that's good.
Regarding the "newfangled shoes", I fretted over going for a pair of xtrac tires for the longest time and finally pulled the trigger. They make a night and day difference over the stock turf tires (sans chains). I have yet to encounter a situation where I need to lock the axle now, so I perpetually run it in open differential mode. Best upgrade I've made to the machine, aside from the impeller kit of course
My machine:
Stang is offline
Likes rod330 liked this post
post #10 of 11 Old 01-19-2020, 02:17 PM
Thanks (Received): 14
Likes (Given): 36
Likes (Received): 28
Never had a new tube, but have swapped in a few oldies. Plumbers teflon tape for a couple loose ones did the trick.
oneboltshort is offline
