New project, maybe a rehash - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 01-18-2020, 11:46 AM Thread Starter
Likes (Received): 39
I received a 924039. In pretty good shape. It has an 8HP with a newer carb missing idle mix adjustment. It also has a differential which seems neat. The bucket is the larger one but the aluminum clam shell auger gearbox is screwed up.
My current machine is a 924032 that looks like **** but is in prime shape. I put a 10HP on it and a bigger auger pulley. It has an iron auger gearbox and new tires, but a straight axle.
I'm toying with a plan to put the engine, tires, and auger gearbox off my 924032 together with the base and bucket of the 924039. Then I could piece the other parts together, fix the gearbox and sell it.
How's that for a plan? How are those old differentials? Are they rugged? I used a newer Ariens with a differential and it wouldn't stay straight on an uneven driveway.
ID:	162645   Click image for larger version
ID:	162647   Click image for larger version
nt40lanman is offline
post #2 of 8 Old 01-18-2020, 12:27 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
The cast iron gearbox from your 924032 would not fit in the bucket of your 924039. The rest of your plan is pretty good, though.
db130 is offline
post #3 of 8 Old 01-18-2020, 12:37 PM Thread Starter
It won't??? They're almost the same machine, I was under the impression similar model/vintage augers were the same.
post #4 of 8 Old 01-18-2020, 12:41 PM
Thanks (Received): 149
Likes (Received): 543
I would fix up both machines, and have a spare Ö. but then again, I have 7 rebuilt machines, so don't go by me Ö lol
oneacer is offline
post #5 of 8 Old 01-18-2020, 01:20 PM
Thanks (Given): 16
Likes (Given): 241
I've been told that the buckets do not interchange. If they did, I would think that at least one of the creative folks on this forum would be running the old cast iron gearbox with the newer bucket.
db130 is offline
post #6 of 8 Old 01-18-2020, 01:52 PM Thread Starter
I'm going to get some measurements and see what's up!!
post #7 of 8 Old 01-18-2020, 01:55 PM
Thanks (Received): 212
Likes (Received): 767
The bucket and gearbox as an assembly will interchange, but the caqst iron gearbox will not fit into the more modern design.
cranman is offline
post #8 of 8 Old 01-18-2020, 04:46 PM
Thanks (Given): 16
Likes (Given): 241
There you have it, @nt40lanman.
db130 is offline
