RapidTrak Pro 28 Belt Shredding - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-22-2020, 05:41 PM Thread Starter
I just purchased a RapidTrak Pro 28. During my initial startup everything appeared normal, until I stepped away from the matching and noticed that I had a handful of pieces of belt under the machine. I removed that back cover plate and nothing jumped out at me, other than there's a lot of belt dust! Anyone have any suggestions? Thanks in advance.
Image at:
https://www.accentalarms.com/images/...m/IMG_2992.jpg
AccentSean is offline
post #2 of 5 Old 01-22-2020, 06:48 PM
Thanks (Given): 9
Likes (Received): 18
Bummer to hear that!
My first thought is that the "attachment clutch cable" is too tight. Mine was a bit tight on my Pro Hydro RapidTrak 28 (but not tight enough to shred the belts luckily).
The attachment clutch is just the Ariens term for the cable that engages the auger/impeller. It can be easily adjusted as per the instructions on page 19 of https://apache.ariens.com/manuals/05136500C_ENG.pdf
That would be what I would check first. I hope this helps!
ericr is offline
post #3 of 5 Old 01-22-2020, 07:53 PM
Thanks (Received): 97
Likes (Received): 259
Actually, that doesn't look too bad. Check to see if the pulley is centered withing the idler pulley. If it is, then it is probably just break-in "dust". But, keep on eye on it...just in case !
RIT333 is online now
post #4 of 5 Old 01-23-2020, 05:59 AM
Could be friction disc dust as well. The track units can be hard on the disc
44964712 is offline
post #5 of 5 Old 01-23-2020, 07:03 AM
Likes (Given): 54
Likes (Received): 33
RapidTrak Pro's are all hydro drive.
kimber is offline
