Ariens 32" idler spring replacement? - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-05-2020, 04:32 PM Thread Starter
Hi... My first post here. I have a big ol' Ariens 32" Model 924042. The drive belt idler spring broke. I bought another spring. How do I get the new spring in there? I can see the old broken one dangling. I see the tag-end also dangling. But it's all close quarters. Anyone have any good info on how I can get in there? I'm a rooky at this but am gung-ho. I can take off the blower and the belly pan and get a view. What next? Thanks!
Jeff Potter is offline
post #2 of 4 Old 02-05-2020, 04:47 PM
Thanks (Received): 212
Likes (Received): 767
split the blower housing from the tractor????
cranman is offline
post #3 of 4 Old 02-05-2020, 05:19 PM Thread Starter
That's easy. But now I see the big drive pulley (about 12" diameter it seems) and the broken spring is dangling BEHIND it, closer to the motor. Is that pulley easy to remove? Seems like I'll have to. If it's easy to, then that will make replacing the spring easy. But otherwise it's a tight squeeze to get behind that.
post #4 of 4 Old 02-05-2020, 06:56 PM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
Throwing out the welcome mat for your first post. Greetings from the Battlefield of Gettysburg.
2019 Ariens Compact 24...
penna stogey is offline
