1336 Pro charging system and LED - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 02-09-2020, 03:54 PM Thread Starter
Thanks (Given): 7
I have a early 2000s 1336 Pro with a 13hp Tecumseh Snowking. It has electric start and an onboard 12v tractor battery. Does this charging system have a built in rectifier to convert the AC to DC? I want to add an LED light, and I see the guys that have pull start with no DC system wiring in a rectifier and capacitors. Do I need to do that if I have the 12v battery on board?
dernt is offline
post #2 of 3 Old 02-09-2020, 10:33 PM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
There Should be a regulator, just outside of the fan housing.
But first, I recommend going to the Ariens site and D/L the Owners, Parts and Service manuals, using your model and serial numbers....
That will tell you Exactly what is there.
GLuck, Jay
JayzAuto1 is offline
post #3 of 3 Old 02-10-2020, 08:02 AM
Thanks (Received): 26
Likes (Received): 85
I'm pretty sure they have a rectifier and regulator for battery charging, but still feed the light and grips with straight AC.
Personally, when I converted a newer Pro to battery start, I fed all of the stator output through the regulator and put the lights, etc. on a switch running from the battery so they always get DC (and the lights don't dim if you idle down to talk to someone).
rslifkin is offline
