Wheel Lockout Trouble - Deluxe 30” - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-09-2020, 07:56 PM Thread Starter
I used my Ariana Deluxe 30” yesterday and both wheels engages perfectly. I had to go back out with it today, and now the left wheel is not engaged and won’t re-engage again. I tried tightening the cable and could hear it engaging inside, but the wheel still spins freely. After taking off the back cover, I can see that using the bicycle-style handle does work it engages inside, but the wheel still spins freely. If I push in on the wheel hard, I can get it to engage a very small amount, but otherwise, it feels like it’s just grinding or clicking as it spins and won’t engage. If I can figure out how to post a video I will, but has anyone ran into this issue? Thanks in advance!
AndrewNL is offline
post #2 of 4 Old 02-09-2020, 08:06 PM Thread Starter
Autocorrect - it’s an Ariens Deluxe 30
AndrewNL is offline
post #3 of 4 Old 02-09-2020, 09:58 PM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
It sounds as if the gear is not getting enough throw on the axle....Which adjusting the cable may or may not have helped.
Before you do Anything else, Go to the Ariens website with your model and serial numbers. There you can D/L the Owners/Parts and Service Manuals, for no charge.
Since you already saw under the belly pan, try watching the gear as you pull on the handle. That gear that moves, may not be moving far enough to be able to re-engage the fixed gear. Notice the Fixed gear on the left side of the shaft?? it actually has 2 different sized teeth. When you pull the handle, it pulls the 2 gears apart. When you release the handle, the 2 gears will mesh. If it lands on the 'Shallow Teeth' that should be Dis-Engaged (One Wheel Drive.... Which I believe it's stuck on now). Pulling & releasing the handle should allow the Gears to mesh on the 'Deep Teeth' (which Should be 2 wheel drive).
Of course, this is from memory, and I don't have your model & serial numbers....But generally that's how they work. Rust is the biggest issue. The next biggest issue, is a mis-adjusted cable. Of course a video will also help, if that doesn't fix your problem.
GLuck, Jay
JayzAuto1 is offline
post #4 of 4 Old 02-09-2020, 11:45 PM Thread Starter
Your memory is correct! The gear in the right shifts and locks in with the deeper teeth on the left gear. In this case, that does happen, but the wheel still spins freely. There is a slight clicking sound as it spins and the gears almost jiggle a little a like the clutch inside is just grazing it. Rust could be a factor, or maybe a stripped gear or clutch? I’ve attached a picture of the gears when closed, but was unable to attach a video. What do you think?
AndrewNL is offline
