Only one impeller turning on my old ST824! - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 02-10-2020, 12:51 PM Thread Starter
I'm not sure what the eggbeater thing is called but I'll go with "impeller." There are 2 in my old 32" ST824. One is turning. What's up? I don't even know where to start to try to fix it. I was given this old machine a year or two ago.
(In our heavy snow the machine is working best as a plow... Do they make a plow attachment?)
Jeff Potter is offline
post #2 of 6 Old 02-10-2020, 01:06 PM
Likes (Received): 22
Sounds like you're talking about your augers. Check your shear pin / bolt. Research snowblower shear pin on YouTube.
BlowerMods1 is offline
post #3 of 6 Old 02-10-2020, 01:08 PM Thread Starter
Thanks! Sounds likely.
post #4 of 6 Old 02-10-2020, 01:26 PM
Thanks (Received): 152
Likes (Received): 549
Correct … shear pin needs replacing … 99% sure …
oneacer is online now
post #5 of 6 Old 02-10-2020, 01:38 PM
Since you're going to be doing some routine maintenance on your machine I would suggest double checking your setup while your at it.
Note: when replacing your shear pin make sure you use another (SHEAR - PIN) and not a regular bolt.
post #6 of 6 Old 02-12-2020, 09:24 AM Thread Starter
Thanks! I got real shear pins.
