924116 duel pulley belt kit - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 02-29-2020, 02:46 PM Thread Starter
Does anyone know if there is a duel pulley belt kit made for the 924116 Ariens snow thrower ? I can only find the kits for the 926 series. thanks in advance.I would like to increase the throwing capacity of my 924 and currently have a auger paddle kit installed but still looking for more.
Grant008 is offline
post #2 of 13 Old 02-29-2020, 02:59 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
to SBF Grant008
post #3 of 13 Old 02-29-2020, 03:10 PM
Thanks (Received): 98
Likes (Received): 260
Not sure if there is, but...I don't think that a dual pulley kit will help much in throwing distance, unless your belt is currently slipping. It will help the longevity of your belt(s) by distributing the load to two belts instead of one, but without any slipping on your current belt, the impeller will still spin at the same speed, and have the same throwing distance. How far are you currently throwing snow, and how far would you like to throw it ? Maybe you need a new belt, and also need to increase belt tension. Also, a spray of Fluid Film in the chute will also increase distance.
RIT333 is online now
Thanks Grant008 thanked for this post
post #4 of 13 Old 02-29-2020, 05:19 PM
Thanks (Given): 19
Thanks (Received): 99
Likes (Given): 745
Likes (Received): 266
welcome to the snow blower forum
87powershiftx2 is offline
Likes Grant008 liked this post
post #5 of 13 Old 02-29-2020, 05:27 PM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
Throwing out the welcome mat for your first post...Welcome from the Burg
2019 Ariens Compact 24...
penna stogey is offline
post #6 of 13 Old 02-29-2020, 05:52 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
There's no dual pulley kit for a 924.
You could look into getting a larger auger pulley, I believe the stock pulley is 2.25" on the drive pulley side and 2.75" for the auger pulley side. I'd try a 3" or 3.25" auger pulley.
db130 is offline
post #7 of 13 Old 03-01-2020, 03:36 AM Thread Starter
thank you to all
I was under the wrong impression then that the duel kit would have a larger pulley as well then. Installing a 3.25 is that possible to install a slightly larger pulley in this 924 ? I believe that the output shaft is a 1" but I'm not 100% sure ? thank you.
Grant008 is offline
post #8 of 13 Old 03-01-2020, 04:39 AM Thread Starter
I've looked with no success in finding a pulley for this application. would you have any links that I could look into ? thank You
Grant008 is offline
post #9 of 13 Old 03-01-2020, 08:07 AM
Try tractor supply, or eBay.
post #10 of 13 Old 03-01-2020, 08:38 AM
Thanks (Received): 14
Likes (Received): 22
You will find what you want here:
http://www.motionusa.com.s3-website-...eaves-1060.pdf
legarem is online now
