Ariens 910014 Auger Issue - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-06-2014, 08:24 PM Thread Starter
Hi All,
My auger decided not to work this morning. I took the belt cover off and can clearly see the auger gear is not engaging with the flywheel. Googled this with no solution. I'm a noob at this stuff I'm assuming once the lever is turned the Auger gear is what extends and connects to flywheel? How does it extend? I do see a spring behind it, but even if I try to pry it towards the flywheel with screwdriver it won't budge.
Thanks for the help!!
helpplease is offline
post #2 of 4 Old 02-06-2014, 08:56 PM
Likes (Received): 42
The spring you see is supposed to make the clutch jaw pop back when it is disengaged. There is a corrosive buildup making it stick in its retracted position. Squirt some penetrating oil like pb blaster where it meets the shaft and let it set for a while. Give it a few taps with a hammer from time to time. It will free up. MH
motorhead64 is offline
post #3 of 4 Old 02-06-2014, 09:54 PM Thread Starter
Wow, much easier than I thought this was going to be Matter of few seconds of PB and the hammer and it popped out. Thanks !!
post #4 of 4 Old 02-08-2014, 11:36 AM
Such good service in this joint! spread the word.
docfletcher is offline
