Need Heated Hand grips ? - Snowblower Forum : Snow Blower Forums
post #1 of 78 Old 02-08-2014, 10:16 PM Thread Starter
Thanks (Received): 98
Likes (Received): 260
In case you wish you had heated hand grips, and don't - like me - I found a cheap solution on EBay. I bought a set of 12 volt heaters for motorcycle hand grips and they cost well under $5. After installing them, I found out that the alternator was strong enough to power the headlight OR the hand grips, and not both - well it would, but neither would be warm or bright enough to be worthwhile. So, when I wired it in, I installed a switch for the heated hand grips and another for the headlight. So, I can have light or heat, or neither.
Installation is easy - you wrap the electric grid around the existing handle-grip, and then cover it with heat-shrink tubing. Everything is provided except the second switch which I also bought off of EBay.
Here is a link to the kit that I bought, and after 2 seasons, it still keeps my hands warm !
Rit
RIT333 is online now
Thanks db130 thanked for this post
Likes Blue Hill liked this post
post #2 of 78 Old 02-08-2014, 10:26 PM
Looks great if you have a lighting circuit. I personally wear gloves with a leather palm and I have never even considered the possibility of the handle bars making my hands cold.
scipper77 is offline
Likes KrowNB liked this post
post #3 of 78 Old 02-09-2014, 07:32 AM
Heated hand grips were a nice bonus on my Platinum 24. I have never considered the option until I was out shopping for a replacement machine.
I must admit I do like the feature and they really do make a difference in comfort. Numb fingertips no more!
markp99 is offline
post #4 of 78 Old 02-09-2014, 09:38 AM
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Rit
Welcome to the forum Rit. Good find. I was lucky enough to get a machine with the heaters already included and for me, in my conditions they are a must have. I wouldn't be without them now, if I had a choice.
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #5 of 78 Old 02-09-2014, 09:57 AM
Likes (Received): 12
It would be nice to know how much these draw, since (especially on older Ariens blowers) there were several different power circuits available. AC, AC/DC, etc.
I personally only have an 18W A/C output intended only for a headlight. We know using a bridge rectifier will get me DC out of it, but without knowing the draw of these handgrips, I dont know if 18W will be enough.
chrisexv6 is offline
post #6 of 78 Old 02-09-2014, 10:46 AM
Thanks (Given): 102
Likes (Given): 273
IIRC, they draw 20W each.
uberT is offline
post #7 of 78 Old 02-09-2014, 11:48 AM Thread Starter
20 Watts per would seem like a bit too much heat. Heck, my soldering iron is 25 watts, and I would not want to get my hand close to that. IMHO
post #8 of 78 Old 02-09-2014, 12:29 PM
Likes (Given): 266
Ariens has told me that they draw 30 watts for the set. My light draws 20 watts and my alternator puts out 60 watts AC.
Larry
post #9 of 78 Old 02-09-2014, 05:31 PM
Thank you for the link. I just ordered myself a pair and will see how they work
Thank You,
Hank
1986 Landmark (MTD) 26" 2 stage with HM80
hankster1 is offline
post #10 of 78 Old 02-09-2014, 07:31 PM
Thanks. Should be helpful if those of us with older models want to try. My 2006 926LE puts out 18W so I cant use these even without the light.
I did have an old Bolens with heated hand grips....they were handy very occasionally (it also had a cab, so between the cab and heated hand grips I could deal with the EOD mess without "gearing up" for the weather)
Never really missed them on my Ariens, I got a decent set of ski gloves (from Costco of all places!)
