What did I break? Auger and impeller won't engage - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 02-13-2014, 03:42 PM Thread Starter
So I went to throw the lever on my 72-73 Ariens today to clear the snow from my driveway and nothing happened... looks like the drive for the impeller and auger won't engage... what did I break?
Lever unengaged
Auger lever engaged...
TIA!
rufushusky is offline
post #2 of 15 Old 02-13-2014, 04:00 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
How about posting the model number of your Ariens ??
post #3 of 15 Old 02-13-2014, 04:08 PM Thread Starter
Thanks for the reply it is 910008...
Older Ariens won't blow snow
Based on this looks like I broke a roll pin or cotter pin... does that seem right? How much of a pain are they to change?
post #4 of 15 Old 02-13-2014, 06:26 PM
Any chance you have the same problem as this guy?
https://www.snowblowerforum.com/forum...ger-issue.html
post #5 of 15 Old 02-13-2014, 07:14 PM
Thanks (Received): 29
Likes (Received): 66
hard to tell by pic.. but looks like the two cog's are not engauged? did the cog that slides on spline impellor shaft get rusted in place? Did the 'U' shape fork that engages it get bent or break?
Geno is offline
post #6 of 15 Old 02-14-2014, 08:02 AM Thread Starter
Looks like I have the same if not similar... looking at the manual it is either the spring stuck or I snapped a cotter pin or roll pin. I will hit it with some kroil and a hammer and see how that goes.
Yeah the jaw clutch isn't moving. The impeller moves by hand. I think the clutch fork is stuck either by broken parts or a stuck spring.
Thanks fellas!
post #7 of 15 Old 02-14-2014, 09:10 AM
clutch fork..
I have seen where it was rusted on shaft from lack of grease.. more stiff than rusted solid though. I'd lube the whole area down there with PB blaster or the likes, let it sit couple hours and then try to move with a long leverage of some kind. The spring broke shouldn't keep it from engaging or moving.. may be wrong on that but visioning in my mind can't see how it would.
Geno is offline
post #8 of 15 Old 02-14-2014, 09:22 AM Thread Starter
Its worth a shot, I mean this thing is 13 years older than I am.
I might just take the whole auger/blower side of snow blower off just to get a better look at everything. Looks like it is just 3-4 bolts holding it on.
post #9 of 15 Old 02-15-2014, 07:58 AM Thread Starter
Well good news (especially with 10 inches of snow on the way), the jaw clutch released last night after being sprayed down with some kroil and a tap with a punch and dead blow it released.
Thanks again!
post #10 of 15 Old 02-15-2014, 08:15 AM
glad to hear- get that area and in the cog cut-outs greased good and the spline shaft under spring too. I use too spray whole area with spray lithium grease after covering as much of that area I could with grease too. Be careful of pulley/belts though.
Geno is offline
