10000 series question - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 02-17-2014, 09:50 AM Thread Starter
Hello,
I have a 10000 series Ariens, not sure of the exact numbers but based on the manual stickied above, thats what it is.
It has been running well all winter untill yesterday, I can't pull the recoil cord anymore to start it (locked up). I have tried taking out the spark plug and spraying wd40 down there, heated the machine up with a heater thinking it may be frozen. The auger and intake blades also seem to be stuck. Oil is good as well. I tried pulling the cord again today and it seemed to come out a bit further (about 6-8 inches) today. Any information would be helpful.
Thank you
mike1818 is offline
post #2 of 18 Old 02-17-2014, 09:52 AM
Likes (Received): 6
Probably broke a connecting rod. Roger
rhenning is offline
post #3 of 18 Old 02-17-2014, 09:59 AM
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 24
When did you last use it? And when you did last use it did it stop abruptly with a big noise? If it was working fine, it's prob not a connecting rod and may just be frozen up and need to be worked free as you are doing. Guys on here will have plenty of advise for you. It may be easier to work it free if you remove the blower housing and put a socket wrench on the flywheel and work it back and forth.
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
post #4 of 18 Old 02-17-2014, 10:09 AM Thread Starter
I used it the day before and it worked just fine, had started up on the second pull. Shut it off normally no signs of it malfunctioning or anything. Went to use it the next day and cord wont pull.
mike1818 is offline
post #5 of 18 Old 02-17-2014, 10:50 AM
Thanks (Given): 24
Likes (Given): 15
This may be a silly question, but do you have the auger engaged? Then would be trying to turn the auger with the motor when you are starting it making it very difficult to turn over.
Ray
1962 Ariens 10ML60
1979 Toro 524
post #6 of 18 Old 02-17-2014, 11:09 AM Thread Starter
Not a silly question, is the handle that engages the auger, the same one that makes the rakes start to turn? Im assuming yes. I believe that is all engaged currently.
mike1818 is offline
Likes Rooskie liked this post
post #7 of 18 Old 02-17-2014, 11:11 AM
At least disengage the belt clutch before attempting to start it.
post #8 of 18 Old 02-17-2014, 11:16 AM
Thanks (Given): 24
Likes (Given): 15
Ok, they should be disengaged so the auger can spin free when the motor is off. This allows you to start it with the motor spinning free and not trying to turn the augers at start up. Maybe something is stuck keeping the auger engaged because you can't spin that either right? You may have to separate the tractor from the auger housing to get in there...?
Ray
1962 Ariens 10ML60
1979 Toro 524
post #9 of 18 Old 02-17-2014, 11:21 AM Thread Starter
Correct, tipped it up on its side and the auger or rakes wont spin.
mike1818 is offline
post #10 of 18 Old 02-17-2014, 11:27 AM
Thanks (Received): 195
Likes (Received): 816
Disconnect Belt, and Spray PB Blaster or WD into spark plug hole. Put a Pipe wrench or Visegrips on the crank and work it free. You'll know if the rod is broken once you free it up. Sometimes seized engines will still work. If the Auger is Frozen, it may be the bearing, or possibly the pin in the gearbox Grenaded and is jamming the gears, or there is some debris jamming the impeller. GL.
Jackmels is offline
