1st oil change - yuk! - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 02-19-2014, 02:54 PM Thread Starter
Platinum 24. Donít think it had 5 hours on it yet, but changed the oil. Looked dark & had a bunch of glittery stuff in it. No big chunks. Hope this is normal.
Notes is offline
post #2 of 21 Old 02-19-2014, 05:33 PM
Likes (Received): 1379
Thumbs up
what you are seeing there is normal. it is from the break in period every thing mating together as it should. it may look like yuk. but in the end it is all good..:c ool:
post #3 of 21 Old 02-19-2014, 05:34 PM
The glitter is probably just residue from the engine and also from the break in process. If it continues to be a problem you may have an internal part issue. For the color with a new engine its usually darker. As long as its not jet black it should be fine. If I were you I would take a look at the spark plug as well to see what shape it is in. If its quite black the carb is probably not working correctly.
3 Ariens 522 Single Stage
Toro 3521 Repowered with a 6.5hp
Craftsman 521 (selling)
other toys
Troybuilt Horse 70s or 80s model
Troybuilt Econo-horse
John Deere Jx75
John Deere Js46
John Deere 111
and a few other parts machines.
Colored Eggs is offline
post #4 of 21 Old 02-19-2014, 05:50 PM
What is the recommended length of time for first oil change?
I have only ran one tank of gas threw my 28 Deluxe so maybe 1 1/2-2hrs.
MnJim is offline
post #5 of 21 Old 02-19-2014, 05:55 PM
Sounds totally normal to me. I'm used to seeing the glittery stuff in the early oil changes in vehicles/ motors/ etc. As long as you don't find actual pieces of metal you're fineÖ Oil color is notoriously unreliable as an indicator of anything so don't read too much into it.
burock is offline
post #6 of 21 Old 02-19-2014, 06:14 PM
Yes totally true on oil color you can't go by that. Glitter in the oil is the norm on first change heck my 20 year old push mower still shows glitter in the oil every season it still runs fine.
Kestral is offline
post #7 of 21 Old 02-19-2014, 06:15 PM
2-5 hrs for break in time. after that 20hrs
post #8 of 21 Old 02-19-2014, 06:27 PM
Most of you are right about oil color not meaning much. Only exception to this rule is that if it is Dark black meaning it needs to be changed badly. (you get this a lot for people that don't take care of their machines) and if its milky white you have gas or water is entering the oil. Other than that though the oil color doesn't mean a thing.
other toys
John Deere Jx75
John Deere Js46
John Deere 111
post #9 of 21 Old 02-20-2014, 09:15 AM
Thanks (Received): 48
Generally after the first 5 hours of operation, every 25 hours thereafter. Use conventional oil for at least the first few oil changes for the break in, after that you can go to synthetic if you wish.
94EG8 is offline
post #10 of 21 Old 02-20-2014, 09:35 AM
Thanks (Given): 173
Likes (Given): 458
Likes (Received): 1037
Read the owner's manual and all the information should be in there. Lots of good information and tips in those manuals.
