Ariens 6hp Tecumseh, series 10,000. - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 02-20-2014, 02:25 PM Thread Starter
What is the correct Champion spark plug for a 40yr old Ariens Snowblower with a 6hp Tecumseh engine?
bongostrates is offline
post #2 of 2 Old 02-20-2014, 04:24 PM
Thanks (Received): 28
Likes (Received): 58
rj19lm or j19lm will work fine gapped at .030"
If you want specifics look on the recoil/pull start sheet metal housing.
find the engine numbers stamped into the steel, on the side on a tag or on top by the plug. if you have electric start it may be under the starter switch box on top.
your model will be H60-12345 or hsk60-12345 or hh60, hs60 etc.. etc..
check this chart on page 5 but i just use rj19lm, works perfect and works well with new gases
http://www.tecumsehpower.com/CustomerService/BSI.pdf
td5771 is offline
