spring - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 03-09-2014, 06:01 PM Thread Starter
spring
i took the bottom cover off to check the disk and belt and found a spring around the gear shaft with the other hooked end connected to nothing , any ideas where i can find where this other end goes , model 926102 st11528le
thanks in advance
JimmyJ is offline
post #2 of 10 Old 03-09-2014, 06:34 PM
Thanks (Given): 173
Thanks (Received): 340
Likes (Given): 479
Likes (Received): 846
Have you checked the manuals? Maybe the parts manual would show it?
You'll need your serial number, in addition to the model number:
Ariens Order Owners Manuals
I was able to download the Owners, Service, and Parts manuals for my machine, for free.
post #3 of 10 Old 03-09-2014, 06:43 PM
Thanks (Received): 147
Likes (Given): 215
Likes (Received): 305
Ha.
When I read the thread title I thought this was going to be another " Is winter ever gonna end???" thread.
Ok. Back on topic. An unattached spring assembly, not an upcoming season.
dbert is online now
post #4 of 10 Old 03-09-2014, 07:24 PM Thread Starter
I've looked at all the manuals and diagrams i see the spring but not what it attaches to, its about 2 inches long with a long hook end, other end slides over the shaft
JimmyJ is offline
post #5 of 10 Old 03-09-2014, 08:50 PM
Thanks (Received): 21
Likes (Received): 55
thanks in advance
In the parts manual for your snow blower, look on page 12, item number 11. There is a spring around the gear shaft, with washer #3 and a pin #12 one one end.
In the owners manual, on page GB-21, lower drawing on figure 18, you can see the spring installed. (If you download the PDF, blow it up to make it clearer by using <ctrl><+> (hold down the control key and tap the "+" key. It becomes clear at around 400%.)
2014 Ariens 24" Platinum
Toro CCR 3650 GTS
enigma-2 is offline
post #6 of 10 Old 03-10-2014, 04:43 AM Thread Starter
its not the large spring that puts pressure on the wheel lock, but a smaller one on the other shaft, thinking it might go to a hole in the wheel lock , cable goes in hole on one side, empty hole on the other side, would like to know for sure. cable not working on wheel lock right now . thanks again
JimmyJ is offline
post #7 of 10 Old 03-10-2014, 11:28 AM
Have a look at the service manual, page GB-41, item number 19. Small spring that goes between the two axles. (In the part manual, page 12, item 19).
Toro CCR 3650 GTS
enigma-2 is offline
post #8 of 10 Old 03-10-2014, 03:34 PM Thread Starter
thats the spring #19 it slides on one axle but doesn't show where hook end goes, any ideas? thanks again
JimmyJ is offline
post #9 of 10 Old 03-10-2014, 03:58 PM
Not certain, looks like one end of the spring hooks on part number 16 (only part on the axle that has a hook for spring attachment and looks like it's used to maintain the teeth in a locked position.)
If the cable hooks into the other end (of part 16) that would make sense, the spring is used to maintain tension on the assy, which is released by pulling the cable.
(Or is the spring already hooked to p/n 16 and it's the other end that's in question?)
Toro CCR 3650 GTS
enigma-2 is offline
post #10 of 10 Old 03-10-2014, 06:04 PM Thread Starter
i hooked it in the hole on part 16, makes sense because cable pulls it other way to release it ,
thanks again
JimmyJ is offline
