Gas fill - Snowblower Forum : Snow Blower Forums
post #1 of 26 Old 03-12-2014, 04:06 PM Thread Starter
Thanks (Received): 21
Likes (Received): 53
Gas fill
Got my new Ariens 24" Platinum yesterday and after I fixed what the dealer screwed up (chute wouldn't rotate full way), we just got clobbered with around 8" of wet & heavy snow. So this was the first time I filled it up with gas and I noticed something I didn't like.
In my old snowblowers, I inserted a funnel, and was able to pour the gas in without caring about spilling. But on the new Ariens, there's some type of insidious plug which prevents the use of a funnel.
I know, "say it isn't so" but they did. Now I use the old style gas containers and when full, the gas starts to leap to it's freedom just around the time I've got the spout about level. This results in gas splashing all over the top of the blower; hence, the need for a funnel.
So, before I rip this little party-pooper out of the top of my new gas tank, I thought I would write in as ask how the rest of you are refueling.
Has anyone found a funnel that will work and defeat the evil Ariens engineers sick joke, or did you end up yanking the contraption out?
(You know, we can go too far with this safety crap.)
2014 Ariens 24" Platinum
Toro CCR 3650 GTS
enigma-2 is offline
post #2 of 26 Old 03-12-2014, 04:31 PM
Vailen's Avatar
I have never heard of this problem before. Can you post a pic?
Ariens Hydro Pro Track 32 (#926514)
Vailen is offline
post #3 of 26 Old 03-12-2014, 04:50 PM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
I got lazy this year and bought a D battery powered fuel transfer pump ($15 ??). It's really handy not having to lift gas cans and it flows at a rate you can easily monitor and shut off before you over fill. I have it in a wagon so I can wheel it to my mowers.
Waiting for warmer weather and will find a way to permanent mount it in one of the gas cans so I don't have to pull it out each time it's used.
post #4 of 26 Old 03-12-2014, 05:01 PM
My gas cans have a built in spout.
My 2014 Ariens Deluxe has a removeable screened basket but I don't bother with removing it.
MnJim is offline
post #5 of 26 Old 03-12-2014, 05:42 PM
mkd
i have the same screen inside my new deluxe 28" and can no longer use a five gallon can and funnel to fill the tank. i use a 2 1/2 gal. round metal tank that has a yellow plastic pour spout that has a 45 degree bend in it and is long enough to pour fuel into the tank without spilling over the machine. my tank also has a lip that directs gas off the tank and also diverts any spilled gas off the hot engine itself if you look at the base of your tank it probably has the same thing. i now pour gas from the five gallon can into the 2 1/2gal can by funnel and then fill the snowblower tank with only the yellow fill snout. my metal can has this pour spout on it and works very good for fueling the machine.
mkd is offline
post #6 of 26 Old 03-12-2014, 06:11 PM Thread Starter
Wish I could, I'm somewhat technically obsolete.
When you look into the gas fill opening, they've inserted sort of like a plastic "cup" with a bar across the center to prevent you from inserting a funnel into the tank when refilling. (And my funnel opening is only about a 1/2-inch in diameter, and it will not allow even that to be used.)
If fact, they specifically state in the owners manual, not to use a funnel when refilling! (Page 23). According to the manual, a funnel will "obstruct" your view of the tank when refueling. The reason given is that they don't want to the tank to be over-filled or it could damage the polution control devices. (Snort)
Toro CCR 3650 GTS
enigma-2 is offline
post #7 of 26 Old 03-12-2014, 06:14 PM
If you are talking about the screen with the red plastic bar across the bottom that is removable, I take mine out fill up the tank and put it back, I think it is there to remove sediment from the fuel you are using to fill the tank. It wouldn't be all that bad if the new gas cans weren't so retarded, you need three hands to use these stupid things.
-Keith-
InfernoST is offline
post #8 of 26 Old 03-12-2014, 06:16 PM Thread Starter
Originally Posted by mkd View Post
i have the same screen inside my new deluxe 28" and can no longer use a five gallon can and funnel to fill the tank. i use a 2 1/2 gal. round metal tank that has a yellow plastic pour spout that has a 45 degree bend in it and is long enough to pour fuel into the tank without spilling over the machine. my tank also has a lip that directs gas off the tank and also diverts any spilled gas off the hot engine itself if you look at the base of your tank it probably has the same thing. i now pour gas from the five gallon can into the 2-1/2 gal can by funnel and then fill the snowblower tank with only the yellow fill snout. my metal can has this pour spout on it and works very good for fueling the machine.
Thanks. Was afraid that this is what's going to required.
Toro CCR 3650 GTS
enigma-2 is offline
post #9 of 26 Old 03-12-2014, 06:22 PM
I have the same thing on my snow blower. I use a gas can with a spout. how did your snow blower perform? gayland
BB Cub is offline
post #10 of 26 Old 03-12-2014, 06:25 PM Thread Starter
That's interesting, do you just pull it out without damaging it?
Toro CCR 3650 GTS
enigma-2 is offline
