Hand Warmers - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 03-14-2014, 07:50 AM Thread Starter
Likes (Received): 6
Hand Warmers
If you purchase a Deluxe, how hard would it be to install hand warmers? Cost? Would there be an issue with the alternator having enough juice? Will Ariens facotry install it? Any info would be appreciated.
SnowGuy69 is offline
post #2 of 7 Old 03-14-2014, 08:37 AM
mkd
my understanding is that the alternator does a better job of one or the other and when you have the light and warmers running it draws just about what the alternator can supply. i beleave 60 watts is the altenator output at governed rpm and lights and handwarmers is 50 watts draw. some people put a switch in the light circuit so the light doesn't run during the day when they run the hand warmers.
mkd is offline
post #3 of 7 Old 03-14-2014, 09:14 AM Thread Starter
Likes (Received): 6
Interesting that Ariens would release a snow blower with two options it could not run
simultaneously.
If that is true, then my theory that they would install a bigger alternator to run both goes out the window. So, back to the first question, how hard are they to install yourself?
post #4 of 7 Old 03-14-2014, 11:02 AM
Thanks (Received): 98
Likes (Received): 260
simultaneously.
Very easy to install if you know how to solder, and have a limited knowledge of electrical circuits. Also - very inexpensive ~$5 if you have a few weeks that you can spend waiting for them to arrive from China, otherwise expensive if you buy them from your dealer $50 or more.
Look at my Thread "Need Heated Hand Grips" for more info on how I, and others, have done it on the cheapo.
Good luck !
Personally, I do not think that they are worth $50+ after using them - but they certainly ARE worth $5 ! IMHO
RIT333 is offline
post #5 of 7 Old 03-14-2014, 12:39 PM
Thanks (Received): 21
Likes (Received): 53
Interesting that Ariens would release a snow blower with two options it could not run simultaneously.
The engine supplies 60 watts AC. (I believe it also supplies 36 watts, full-wave DC, on the red battery charge line - normally not continued past the engine connector).
Anyway, the handwarmers draw 30 watts & the halogen light draws 20 watts, so both can operate simultaneously with 10 watts to spare.
Here's a YouTube video of a guy installing handwarmers on an Ariens. He used ATV handwarmers for $40 off of Ebay (instead of the $80 that Ariens charges).
2014 Ariens 24" Platinum
Toro CCR 3650 GTS
enigma-2 is offline
post #6 of 7 Old 03-15-2014, 01:53 PM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1741
It's a matter of you get what you pay for. I'm sure those 65/85 dollar kits the dealer sells which are imbedded in new grips and draw an extra 50% power to run on likely do heat better. They also have the wiring and connectors to be plug and play.
I'm waiting on my slow boat from China literally !!! Won't be able to try them in the cold when they finally arrive I think I'm close to 30 days now.
post #7 of 7 Old 03-18-2014, 02:40 PM
Thanks (Given): 589
Likes (Given): 4358
That wait is a real pain. I ordered mine from ebay "Lioncitysg" on Feb 17th and I'm still waiting for them to arrive. Sent them an Email asking when to expect the heaters and was told could take up to 35 days
