New Hydro Pro 36 - Draining gas tank. - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 03-27-2014, 12:20 AM Thread Starter
Likes (Received): 8
On my old Ariens ST1236, with the Tecumseh Snow King engine, I always drained the gas out of the tank, ran the engine dry and then drained the carburetor bowl, via the spring valve in the bottom of the bowl, for summer storage.
Today I received my 36" hydro pro and in looking it over briefly I don't see a way to easily drain the fuel tank and the bowl.
Now I know there was another thread recently stating the recommended storage procedure is to leave the tank 3/4 full using stabilizer, and my new manuals states the same, but draining everything has been a bullet proof method for years.
So, those of you that have the 420CC Briggs motor have you found a way to easily drain the gas out of the tank and bowl? (aside from letting the engine burn it off)
Matt
Ariens Hydro Pro 36
MattM is offline
post #2 of 17 Old 03-27-2014, 07:56 AM
Likes (Received): 1379
just run the engine until it's dry and dies.
post #3 of 17 Old 03-27-2014, 10:20 AM
Thanks (Received): 98
Likes (Received): 260
That will still leave some gas in the carb bowl - maybe not enough to worry about, but I always worry about it, and srop the bowl. I also try to run a rag around the inside of the fuel tank just to get it completely dry - but that is my anal-self.
RIT333 is online now
post #4 of 17 Old 03-27-2014, 01:55 PM
just put a little bit of Stabil or seafoam in the tank when you run it dry and it'll be juuuuust fine.
Ryan is offline
post #5 of 17 Old 03-27-2014, 04:12 PM
I can be very anal about changing the oil even if has 10 or less hours on it. but I have been doing this for 30 odd years running it all dry. never ever had a problem come the next year. anyway I thought I would run that up the old flag pole to see if it flies.:eek :
post #6 of 17 Old 03-27-2014, 07:27 PM
Oil is cheap - The 20 qts of oil that you used over the 30 odd years is very cheap engine-insurance - IMHO.
post #7 of 17 Old 03-27-2014, 08:34 PM
Thanks (Received): 21
Likes (Received): 54
Amazon:
2014 Ariens 24" Platinum
Toro CCR 3650 GTS
enigma-2 is offline
post #8 of 17 Old 03-28-2014, 01:26 AM Thread Starter
Likes (Received): 8
Thanks for the replies guys.
I was hoping for something a bit more crafty and artful than the $10 leaky pump from the auto parts store but I suppose its an option.
Matt
Ariens Hydro Pro 36
MattM is offline
post #9 of 17 Old 03-28-2014, 06:09 PM
Thanks (Received): 143
Likes (Received): 297
Were you thinking about something like this:
post #10 of 17 Old 03-28-2014, 08:59 PM
Thanks (Given): 589
Likes (Given): 4364
Likes (Received): 1742
You can always go electric for about $15
Homedepot, northern tool, walmart .....
