Question on 932 101 drive output shaft play - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 03-30-2014, 12:33 PM Thread Starter
Likes (Received): 12
I have been messing with this machine all winter and it got me through . The drive belt had come off and flipped which messed it up a bit but it got me through the winter. I pulled the front end off to put new ones on and noticed that the front output pulley off the gear gox (big lower one) has a lot of play in it , 16"th of inch wobble. When I pull the handlebar lever it goes away and feels fine. Most of the play is in the back end away from the pulley. Is that the way it's supposed to be? I'm assuming so due to the friction wheels allowed movement but want to be sure before I put it back together. Thanks.
driz is offline
post #2 of 7 Old 03-31-2014, 06:18 AM
Likes (Received): 42
driz
It might help if you can post a photo. I pulled up your parts breakdown and with your description of the problem... still scratching my head. Not sure exactly what you are describing. It looks like you have a "bushing" on the impeller shaft that, if worn, would give you a wobble. But still not sure what your problem is. MH
motorhead64 is offline
post #3 of 7 Old 03-31-2014, 09:24 AM Thread Starter
I don't think you would see much on pic so I'll try again. It the shaft that connects to the friction disk. The pulley end is loose . I played with it a bit but notice
when the drive lever I'd depressed that the pulley rises into full verticaL and the slop is completely gone. It sure feels. Like its made that way to me but I want to be sure before I put it back together .
driz is offline
post #4 of 7 Old 03-31-2014, 09:59 AM
Parts and Diagrams for Ariens 932101-000101 ST824, 8hp Tec., 24" Blower
Can you identify the part from this diagram? MH
post #5 of 7 Old 03-31-2014, 12:40 PM Thread Starter
I guess the slop is in # 27 BUSHING FLANGE. Should that move up and down freely until the lever is squeezed (which takes all the slop out)... The rear end of that shaft is pivoting towards the rear center I would guess. As I said it feels like something that was engineered that way as I never saw any sloppy worn bearing behave that way. I haven't pulled the studded collar off the shaft yet though to actually look at it. I was expecting more of a "no dummy the slop lets the pulley disengage from the belt answer".
This 824 is in pristine shape. Not the sort of thing I would expect to have extreme wear like this in.
driz is offline
post #6 of 7 Old 03-31-2014, 01:29 PM
The bushings should not allow wobble to occur, but if, when you engage the auger, the wobble doesn't occur, you may be able to run like that for quite a while before things get noticeably worse. Tension on anything that is wobbling will reduce it, but the wear on the bushings/bearings will be accelerated. I would just keep an eye on it and know that it will get worse over time. MH
post #7 of 7 Old 03-31-2014, 04:49 PM Thread Starter
Ok, after posting this in another thread here it is.
That pulley goes up and down about 5 degrees, or should I say in and out at the top. When the drive handle is depressed it's fully upright at 90 degrees. I don't see any other means of engagement / disengagement for the drive belt that enables it to slip. Thats why I think it must be made that way.
ID:	14946   Click image for larger version
driz is offline
