auger rubbing - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 04-10-2014, 05:43 PM Thread Starter
auger rubbing
was just putting snowblower away for the year and noticed the front augers are rubbing inside in the back, not getting much play in it and they are not hitting right now, **** near cut thru the housing, any ideas?
JimmyJ is offline
post #2 of 6 Old 04-10-2014, 06:09 PM
did youy hit something to bend the augers
post #3 of 6 Old 04-10-2014, 07:06 PM
Likes (Received): 42
Make sure the bucket is tight to the tractor assembly. If the attachment screws are loose, the bucket can flex while working, resulting in occasional contact with the augers. The other issue can be ice and stones/debris that freeze to the rakes after work is done. Next time out, they scrape the bucket until they work loose. MH
motorhead64 is offline
post #4 of 6 Old 04-11-2014, 05:33 PM Thread Starter
this happened on my last time out with it, was cutting back some deep heavy banks with it,
JimmyJ is offline
post #5 of 6 Old 04-11-2014, 05:54 PM
I would check the auger bearings The 2 on each side of the housing and also the back bearing to see if its moved. If not sounds like you bent the auger.
3 Ariens 522 Single Stage
Toro 3521 Repowered with a 6.5hp
Craftsman 521 (selling)
other toys
Troybuilt Horse 70s or 80s model
Troybuilt Econo-horse
John Deere Jx75
John Deere Js46
John Deere 111
and a few other parts machines.
Colored Eggs is offline
post #6 of 6 Old 11-07-2014, 07:19 AM
Thanks (Received): 17
Likes (Received): 79
did you ever find out what the problem was with this ?
the only machine I had that did that, was the Gilson 55012, and the auger shaft was bent, and the mid bearing on its way out.
1967 S-242 Snowbird 4/24
Gilson 55012 8/26 gear drive
Ariens 910010 8/32
Cub Cadet 268 8/26
Yard-Man Snowbird 7040-0 5/22
Ariens 10M-L35 3.5/24
greatwhitebuffalo is offline
