ariens gear set wanted - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 07-11-2014, 08:59 PM Thread Starter
i have an ariens 10000 series with stripped auger gear set. it is a 7hp with a jam clutch and 24 inch gearbox, the model number is worn off so i dont have a model number for you guys. if anybody has an auger gear set they would be willing to sell/give away, please contact me at evanm[email protected]. any help is greatly appreciated
post #2 of 9 Old 07-11-2014, 10:31 PM Thread Starter
the box itself just the gears are bad by the way, only need the gears
post #3 of 9 Old 07-12-2014, 06:14 AM
Thanks (Received): 17
Likes (Received): 79
pretty sure you can buy those gears ? on Ebay as a set ?
greatwhitebuffalo is offline
post #4 of 9 Old 07-12-2014, 09:52 AM Thread Starter
i looked, the only thing ebay has is complete gearboxes
post #5 of 9 Old 07-14-2014, 05:54 PM Thread Starter
i got a chance to tear her down today, here are some pics, to make matters worse, when the augers presumably hit something, the power was presumably transferred to the engine causing it to throw a rod.
both failures were probably assisted by the thin black gasoline contaminated oil in the crankcase and some idiot filling the gearbox with grease
post #6 of 9 Old 07-14-2014, 08:51 PM
Likes (Given): 215
Likes (Received): 304
Wow. Simultaneous failure of connecting rod and gearbox!
Anyone ever heard of that before?
So which caused which?
Some gearboxes are supposed to have grease vs oil. I don't think the 10000 series did though.
dbert is online now
post #7 of 9 Old 07-14-2014, 09:23 PM Thread Starter
i think the guy hit a brick or something and the force from hitting it ruined the gearbox, and the force from the impact was transferred to the engine and broke the rod, but thats just a theory. there was a lot of carbon buildup in the head of the poor little h70 and it fell into the cylinder and caused scoring, so even though the block had no holes in it it would require an oversize bore and rings, carburetor replacement, and a bunch of other stuff i dont want to deal with. the left side auger had a bolt in it and the right had a shear pin so thats probably what caused the failure. as you can see there is absolutely no usable portions of either gears left, if you know somebody who can source the two i would appreciate it
post #8 of 9 Old 07-14-2014, 10:02 PM
Likes (Given): 215
Amazing that the sudden stoppage of the impeller broke the connecting with a belt drive in between.
Perhaps someone took two bad parts and mounted them to together while they made themselves a good one.
dbert is online now
post #9 of 9 Old 07-14-2014, 10:08 PM Thread Starter
the guy said he pulled the starter from it and thats it, the belt did look relatively new and had almost no slack.
