offset Impeller - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 03-28-2013, 12:27 PM Thread Starter
offset Impeller
hello
I need some help and guidance for my Ariens ST 30 LE deluxe snowblower
the model number is 921013.
I am going to install a Clarence impeller kit because I also am having trouble
snow blowing even a couple inches of wet snow. The machine worked great
in the blizzard of 2013 where the snow in my driveway was 21 to 23 inches
of snow.
The question I have is after taking off the top chute the impeller is offset
To the rear of the discharge hole almost 1 inch. The impeller is also over
5/16 inch gap in some places. I contacted Ariens about the offset impeller
and they said it was normal. Looking into my neighbors Honda this impeller l
is lined up with the discharge hole leading to the chute perfectly.
also the impeller clearance in his machine is only about 1/8 inch clearance
in his houseing. Contrary to what Ariens told me all snowblowers have trouble moving wet snow.
His Honda running next to my is throwing a wet snow 10 feet father than
my Ariens.
What are your thoughts on removing the role pins and moving the impeller to center up to discharge hole by re-drilling the role pinholes?
also do you think the Clarence impeller will be a improvement throwing wet snow.
My machine has the 342 cc engine and has plenty of power even in the big drifts.
Ed
fast eddie is offline
post #2 of 8 Old 03-28-2013, 03:21 PM
Likes (Received): 39
Post some pictures of the machine and the offset. Big machines like to have lots of snow and can peter out if you're not feeding them enough.
nt40lanman is offline
post #3 of 8 Old 03-28-2013, 08:23 PM
Likes (Received): 344
Impeller issue
Eddie
First off, welcome to the forum.
I'm not familiar with your particular model but like has been asked, I'd like to see some pictures of the issue.
On your thoughts on moving the impeller, that would be a last resort to me. If you move it closer to the rakes you effectively put a larger void between the back of the impeller and the housing where it can pack with snow.
If I wanted the impeller vanes to be longer, I would be inclined to 'make' a impeller kit. I'd make the belting longer and I'd have 2 pieces of metal on it, one on the top and one on the bottom with each the length of the belting.
That way you'd close the gap, extend the impeller vanes and not increase the gap behind the impeller.
I'd still like to see pictures first though, because I could be completely wrong.
HCBPH is online now
post #4 of 8 Old 03-29-2013, 10:12 AM Thread Starter
offset impeller
enclosed are a few pics of the impeller
Ed
ID:	1498   Click image for larger version
ID:	1506   Click image for larger version
ID:	1514   Click image for larger version
ID:	1522   Click image for larger version
post #5 of 8 Old 03-29-2013, 01:56 PM
I'd leave it right where it is. I wouldn't want to move it from the back of the housing and I think close to the back of the opening is the best place for snow to come out, right in line with the chute.
post #6 of 8 Old 03-29-2013, 05:29 PM
Moving impeller
Agree
Add the impeller kit if you so desire but leave the impeller depth alone (my opinion).
HCBPH is online now
post #7 of 8 Old 12-24-2014, 10:00 PM
Thanks (Given): 171
Thanks (Received): 307
Likes (Given): 437
Likes (Received): 1019
Hey Fast eddie,
Did you ever put the impeller kit in your blower?
post #8 of 8 Old 12-24-2014, 10:24 PM
RoyP's Avatar
Likes (Given): 7
This is NOT going to be easy for you to re drill holes in your drive shaft for this. Once this is done, you always have the option to put the impeller back where it was originally. From looking at your pictures.....i would go for it........then decide what is best for you.
You may have tripped on something that i wrong with these machines
As for the impeller kits, Your impeller looks great. run without it.
RoyP is offline
