Ariens 921038 platinum SHO stock LED headlight - Snowblower Forum : Snow Blower Forums
post #1 of 23 Old 09-02-2014, 07:23 AM Thread Starter
I ordered the 921038 model from snowblowers direct. Their specs say LED headlights. Can anyone confirm this? I started ordering the parts to upgrade the lighting before I saw that. The ariens site or catalogues has no mention of this. Full specs are below with the LED highlighted.
Model
Model Number: 921038
UPC: 751058038353
Manufacturer: Ariens
Engine
Brand: Ariens
Type: 4-Cycle OHV
Power: 306 cc
Torque: 15 ft-lbs Net Torque
Starting System: 120-Volt Electric /w Recoil
Fuel Tank: quarts (0.00 liters)
Auger
Diameter: 14 (35.56 cm)
Material: Serrated Steel
Impeller
Profile: Steel 3-Blade
Chute
Material: Steel
Chute Rotation: Quick-Turn
Turning Radius: 200
Drive System
Drive: Disc-O-Matic
Steering: Auto-Turn
Gear Case: Cast Iron
Forward Speeds: 6 Forward
Reverse Speeds: 2 Reverse
Tire Type: Polar Trac
Tire Size: 16" x 5" (40.64 cm x 12.7 cm)
Remote Deflector Contols: Yes
Drift Cutters: Sold Separately
Front Weights: Sold Separately
Interlocking Controls: Yes
Hand Warmers: Yes
Headlights: LED
Skid Shoes: Included - Reversible
Thanks,
fe342185 is offline
post #2 of 23 Old 09-02-2014, 07:34 AM
Likes (Received): 1379
ALOHA to the forms..: cool: as far as I know they are LED lights.
post #3 of 23 Old 09-02-2014, 06:46 PM Thread Starter
Hmmm. This throws a wrench to my Aux LED project.
fe342185 is offline
post #4 of 23 Old 09-02-2014, 09:26 PM
Thanks (Received): 22
I bet that your auxiliary LED project would be MUCH brighter than the stock LED. Just a guess though
Snowblowers I own.
Honda HS928
Honda HS621
superedge88 is offline
post #5 of 23 Old 09-02-2014, 09:49 PM
Thanks (Received): 143
Likes (Received): 297
But, it might eliminate your need for the rectifier.
post #6 of 23 Old 09-03-2014, 08:57 PM Thread Starter
I agree. I just received and tested the 18 watt led and its superbright. It puzzles me that snowblower manufacturers continue to place lights that are obviously inadequate especially with todays technology. It seems like every manufacturer places the light in the same place. In my opinion it should be placed somewhere in front of the chute. Being a first time 2 stage snowblower owner, is this not feasable?
I was thinking of fabricating a bracket to come up a few inches above the impeller housing and just in front of the chute.
fe342185 is offline
post #7 of 23 Old 09-03-2014, 10:59 PM
I agree. I just received and tested the 18 watt led and its superbright. It puzzles me that snowblower manufacturers continue to place lights that are obviously inadequate especially with todays technology. It seems like every manufacture places the light in the same place. In my opinion it should be placed somewhere in front of the chute. Being a first time 2 stage snowblower owner, is this not feasable?
Personally I would mimic what Honda does, in all my hours of brainstorming headlight location it seems that Honda has one of the smarter locations that avoids the most shadows (ideally at least two separate lights are used for zero shadows) . If you mount a light in front of the shoot you do run the rare risk of burying it in snow if you push the bucket into a large snow drift.
Snowblowers I own.
Honda HS928
Honda HS621
post #8 of 23 Old 09-04-2014, 04:30 AM
look at VAILEN'S snow blower in the gallery. a little overkill if you ask me..:rolle yes:
post #9 of 23 Old 09-04-2014, 01:07 PM
Curious if you'll modify it to reduce eye glare when tipping up the bucket on turns etc. Seems to be a common complaint with the new dash config.
cabinfever is offline
post #10 of 23 Old 09-04-2014, 07:16 PM Thread Starter
I got the call today that it will be delivered tomorrow morning. I will post pics of the light.
fe342185 is offline
