1978 Ariens 824 Engine Sheave Removal - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 09-01-2013, 08:32 AM Thread Starter
Folks, I have an older Ariens 824 and need to replace the idler arm spring behind the engine sheave. I have tried loosening the sheave nut and cant get it to move. It looks like normal direction threads and I dont see any pins. Any advice would be appreciated.
Name:	Ariens 824 Front Engine Sheave.jpg
GordS is offline
post #2 of 5 Old 09-01-2013, 10:44 AM
Are you sure you can't get to the spring with it in place? I pulled one off a smaller compact blower, but don't remember how I held it still. I think mine might have had a hole in it and I held it still with a screwdriver.
post #3 of 5 Old 09-01-2013, 10:14 PM
Jackmels's Avatar
Thanks (Given): 108
Thanks (Received): 164
Likes (Given): 347
Likes (Received): 648
It will Come off if You Heat it Cherry Red with a Torch. Regular Threads IIRC.
Jackmels is offline
post #4 of 5 Old 09-02-2013, 08:10 AM Thread Starter
Thanks Shyrp & Jackmels. It's tight behind the sheave and I cant see in there well enough to manipulate the spring to where it needs to go. I will try removing the sheave nut with the torch and let you know how it goes.
GordS is offline
post #5 of 5 Old 09-03-2013, 10:44 AM
td5771's Avatar
Likes (Received): 57
If all else fails, take it apart from the other side a bit and maybe you can get the pulley and shaft to come out the front togetber
td5771 is offline
