522 Chute Spins To Straight Forward - Snowblower Forum : Snow Blower Forums
Old 02-04-2015, 11:19 PM Thread Starter
My 522 chute spins itself forward from left or right position. Is there an adjustment to tighten and better lock in position?
Also - is it possible to make the impeller engagement linkage too tight?
shacky is offline
Old 02-05-2015, 09:02 AM
Thanks (Given): 485
Thanks (Received): 354
Likes (Received): 1178
the impeller question is yes it possible the 1st question I would need a pic to see what is going on there.
Old 02-05-2015, 09:52 AM
Motor City's Avatar
Thanks (Received): 48
Likes (Received): 52
On some of the 522's their is a spring and a detent ball. The spring will fail, thus allowing the chute to spin. You'll have to dis-assemble the chute assembly and replace the spring. I was able to match up a spring at the hardware and grease up the parts, when you re-assemble it.
Ariens ST11528LE
Honda HS720
Motor City is offline
Old 02-07-2015, 05:11 PM
jampg is offline
Old 02-07-2015, 11:14 PM Thread Starter
Thanks jampg!
What screw/screws do I need to remove to get top of chute off to replace spring and rivet? #8 in chute bow up here?
Lawn Mower Parts, Small Engine Parts & Much More! | PartsTree.com - Briggs, MTD, Toro, Cub Cadet, Husqvarna, Troy-bilt...
shacky is offline
Old 02-08-2015, 08:44 AM
Thanks jampg!
Yes sir. Once you remove the chute discharge, there are 4 self tapping screws. This is a pretty easy job. Order parts 23 and 24. My original parts were missing. Installing a new rivet and spring will do the job.
When you reinstall the chute, you need to pay attention to the amount of torque you put on the four self tapping screws. Too much and the chute will not turn. I had to back mine off a little to get it to rotate.
My brother and I have the same model and this November they will be 20 years old. WOW!
jampg is offline
Old 02-08-2015, 09:17 AM Thread Starter
Mine's about 14 years old. Froze a bearing a few years ago - thought the engine seized but it was a bearing on drive belt.
Other than couple of carborators it's bean great. Guess I should use ethanol free gas.
shacky is offline
Old 02-08-2015, 09:50 AM
This machine has been very impressive. Pretty much bullet proof other than a belt here and there which is to be expected.
I think the next one may be a Compact 24.
jampg is offline
Old 02-08-2015, 10:56 PM Thread Starter
I don't have to remove cowl do I?
shacky is offline
Old 02-09-2015, 08:21 PM
No, just the discharge chute and the handle.
jampg is offline
