Picked up a 1979 Ariens 924040(8hp 24") - Page 6 - Snowblower Forum : Snow Blower Forums
post #51 of 57 Old 01-29-2020, 06:35 PM
Thanks (Received): 208
Likes (Received): 764
If you got a big enough engine to power it, it is a beast.....I've got a 12 OHV Tec on that same platform with a 3.5 inch impeller pulley, and it is just right.....
cranman is offline
post #52 of 57 Old 01-30-2020, 02:43 PM Thread Starter
db130's Avatar
Thanks (Given): 16
Likes (Given): 237
Likes (Received): 196
The belt saga continues
The 39.5" belt does fit, but I have to set the tensioner to maximum to get sufficient tension on the belt, and as I expect the belt to stretch out a bit after use, it's not ideal.
As I have another snowblower than can use the 39.5" belt, I'm going to try a 39.3" belt next.
There is a 39.3" Toro belt (PN 26-9671) en route.
db130 is online now
post #53 of 57 Old 01-30-2020, 05:57 PM
it shouldn't be that critical...is the impeller bearing good?
cranman is offline
Likes Jackmels liked this post
post #54 of 57 Old 02-04-2020, 11:25 AM Thread Starter
db130's Avatar
Thanks (Given): 16
Likes (Given): 237
A new impeller bearing was installed on Jan 2019 and had had about 90 minutes of runtime since. It wasn't the impeller bearing.
The right belt makes all the difference, guys, especially in a custom setup.
Here's the 39.3" belt. It went on like butter and it's juuuust right (additionally, the tensioner is at minimum and I can adjust as needed going forward).
To recap...
2.75" pulley used a 38" belt (had to be stretched out just a tad by running)
3" pulley used a 39" belt (tensioner was at minimum)
3.5" pulley used a 39.3" belt
According to the part number, it's used by 35 different Toro snowblowers and mowers, so it should be available indefinitely.
Back to waiting for snow, unfortunately.
db130 is online now
post #55 of 57 Old 02-04-2020, 12:12 PM
Thanks for the info, good to know.
cranman is offline
post #56 of 57 Old 02-04-2020, 12:29 PM
Thanks (Given): 229
Likes (Given): 2021
Likes (Received): 515
You just screwed us db... We may as well summer-ize our snowblowers now
Your perseverance paid off! she's gonna really chuck it!
('87 Toro 38150 826)
classiccat is online now
Likes db130 liked this post
post #57 of 57 Old 02-04-2020, 04:37 PM Thread Starter
db130's Avatar
Thanks (Given): 16
Likes (Given): 237
What I meant to type was... as I'm SURE that we're not getting any more snow this winter, I'm going to run it dry and wait for next winter.
db130 is online now
Thanks classiccat thanked for this post
