1973 Ariens shredded new drive belts! - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 03-15-2015, 10:50 PM Thread Starter
Likes (Given): 48
Likes (Received): 74
I got my old Ariens back together and was testing it out on some snow today, when after about 20 minutes of running, it stopped moving forward. I pulled it into the garage, took the belt guard off and saw that the 2 drive belts were shredded!
I'm kind of at a loss as to what caused brand new belts to be destroyed that quickly! The only thing I can think of is that the idler pulley doesn't spin very freely, and that caused them to break? It will turn, but stops spinning as soon as I stop turning it. Is it supposed to turn freely and keep spinning?
Any suggestion?
Cub Cadet 2X 524 SWE
caddydaddy is offline
post #2 of 20 Old 03-15-2015, 11:03 PM
maybe the bushings/bearings in the pulleys are bad
post #3 of 20 Old 03-16-2015, 12:29 AM
Likes (Received): 10
that could do it yes
1984 Columbia 10hp-33in
2015 Columbia 420cc 28in 3xHD
Marty013 is offline
post #4 of 20 Old 03-16-2015, 07:03 AM
94EG8's Avatar
Thanks (Received): 48
Usually when that happens the belt is running on the wrong side of a guide or the brake arm for the auger pulley.
94EG8 is offline
post #5 of 20 Old 03-16-2015, 09:34 AM Thread Starter
Likes (Given): 48
I'm pretty sure I routed the belts correctly, and it was working fine, just for 20 minutes though. It went forward in all gears and reverse worked.
Could a belt have slipped off the idler pulley?
post #6 of 20 Old 03-16-2015, 10:36 AM
Thanks (Given): 511
Thanks (Received): 682
Likes (Given): 3849
Likes (Received): 1479
The idler should spin for a while on it's own. When you hold the center and then rotate the outside it shouldn't have any resistance and it should feel silky smooth. If you feel resistance or any grinding the idler is shot.
That may be the problem but I'm also curious if the belt's alignment was off or if the auger housing was tight to the transmission body? Also check to see if any welds might be broken in the mounting area allowing some flexing under stress which would cause belt misalignment and promote excessive belt wear/failure.
post #7 of 20 Old 03-16-2015, 05:58 PM
94EG8's Avatar
I've seen them work for about that long before when routed incorrectly, it's not always instant death.
Possibly, but the only way you'll know is to look.
94EG8 is offline
post #8 of 20 Old 03-16-2015, 08:45 PM
Thanks (Given): 511
Likes (Given): 3849
If possible show us pictures.
post #9 of 20 Old 03-17-2015, 12:23 AM Thread Starter
Likes (Given): 48
Certainly:
post #10 of 20 Old 03-17-2015, 12:41 AM Thread Starter
Likes (Given): 48
I pulled the tensioner arm off and the pulley bearing does make some noise when spinning. I'm not sure if that's the problem, but I'm sure it's not helping!
Has anyone replaced the bearing in one of these before? The parts online that I saw looked really expensive! There's gotta be a cheaper way to fix it!
