Anyone have instructions or a pic of the Friction Plate Assembly - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 06-19-2015, 08:08 AM Thread Starter
I need to figure out how to assemble the plate to the metal bracket.
I would need a pic in between (on the inside) the plate and the large metal bracket.
I only have found pic of the top or bottom.
This I need in between pic
krisnet55 is offline
post #2 of 6 Old 06-19-2015, 11:11 AM Thread Starter
I need a pic like this. Im not sure if 2 of those gold bushings are used, one opposite to the other, or just one.
ID:	52194   Click image for larger version
post #3 of 6 Old 06-19-2015, 09:15 PM
I don't know how that is set up, but I know the older Ariens used a 2 piece design to hold the impeller bearing from both sides.
post #4 of 6 Old 06-20-2015, 08:36 AM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
Which Ariens do you have ?? Model # ??
post #5 of 6 Old 06-20-2015, 09:58 AM Thread Starter
921022 Deluxe 28
I'm not sure how tight tolerances are but this thing is all over the place, lol.
I took that plate off to give it a good clean and lube but when spinning the plate there is a slight wooble.
post #6 of 6 Old 06-20-2015, 10:02 AM Thread Starter
I also noticed that the other pulley is very close to the frame of the bucket to the point that there are some rub marks. I took it apart thinking maybe some washer was missing, but according to the schematics it's all there.
Then again I've already found some errors on the schematics themselves.
