Ariens model 924050 summer attachments - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 08-20-2015, 04:24 PM Thread Starter
I have an Ariens 924050 snow thrower with a brush attachment. I read on the heat shield for the carburetor that I need to install the air filter kit to use the brush. I have called around and everyone is saying that the parts are obsolete and can't be found. I can not use this brush without it or I will destroy the engine. Can anyone please help? Here are the part numbers:
Ariens PN: 02400500, 02447100, and 06701900. I can't find a part number for the air intake pipe so that's a problem as well. Is there a substitution for these parts? Please help!!
omniplayer is offline
post #2 of 8 Old 08-20-2015, 04:35 PM
remove the heater box, the choke plate and install an air filter adapter in the heater boxes place. found a new one on ebay but its not cheap.
post #3 of 8 Old 08-20-2015, 04:44 PM
Check your local craigslist for maybe a rototiller with a blown engine or something like that. Most engines are basically the same for summer and winter use. The biggest difference is air filter vs heater box. Most parts should swap over.
Depending on the condition of your engine you could always get a new engine too. People love the clone engines.
post #4 of 8 Old 08-20-2015, 10:14 PM
yeah the predator would swap right on
post #5 of 8 Old 08-22-2015, 09:39 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
Comes with the carb/intake pipe/air filter housing.
db130 is offline
post #6 of 8 Old 08-22-2015, 10:42 PM
yeah but its still 70 bucks for an epa non adjustable carb
post #7 of 8 Old 08-22-2015, 10:53 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
I have an air filter assembly, send PM if interested.
Jackmels is online now
post #8 of 8 Old 08-23-2015, 07:33 AM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
Welcome to the forum omniplayer
You could also take your engine numbers, carb number and carb itself or a couple photos of it to some local small engine shops and maybe someone might have a compatible air filter assembly sitting on a blown engine or laying on a shelf that they will set you up with cheap ??
Don't know unless you try.
