New Compact 24 with tight/sqeaky chute rotation - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 09-04-2015, 09:11 PM Thread Starter
Thanks (Given): 79
Thanks (Received): 83
Likes (Given): 329
Likes (Received): 362
This floor model at the H-D had something funky going on with it. I am assuming this is not normal because the Deluxe 28 next to it (with the ice drill) was like butter.
1989 John Deere 1032
tdipaul is offline
post #2 of 9 Old 09-04-2015, 10:32 PM
Thanks (Given): 33
Thanks (Received): 37
Likes (Given): 64
Likes (Received): 87
I wouldn't be able to comment because your video is set to private.
Oh well.
2015 Ariens Deluxe 28+ 921037, 414cc LCT (now son's)
2014 Ariens Platinum 30 921029, 414cc LCT (mine forever)
PixMan is offline
post #3 of 9 Old 09-04-2015, 10:54 PM Thread Starter
Thanks (Given): 79
Likes (Given): 329
Fixed
tdipaul is offline
post #4 of 9 Old 09-05-2015, 06:50 AM
Thanks (Received): 7
Likes (Received): 15
Something is either too tight or needs some grease!
cbnsoul is offline
post #5 of 9 Old 09-05-2015, 07:07 AM
Thanks (Given): 33
Likes (Given): 64
Agreed.
One of the things added at assembly upon delivery is the chute and I believe it's advised to lubricate with grease the mating surfaces of the bottom of the chute and top of the auger housing. Looks like someone missed that detail, which isn't uncommon in the big box stores.
There's another example of why buying from a reputable, experienced power equipment dealer is preferred.
By me anyhow.
PixMan is offline
Likes tdipaul liked this post
post #6 of 9 Old 09-05-2015, 07:26 AM
liftoff1967's Avatar
Thanks (Given): 36
Thanks (Received): 45
Likes (Given): 65
Likes (Received): 94
Can be fixed one of 2 ways.
  • 9/16" wrench to the underside and back off the loaded spring bolt 1 or 2 turns
  • little shot of lubricant to the underside area of the loaded spring
My deluxe 30 does the same, as shown in my videos. Fine line between lubricating it enough not to squeak yet still able to hold the chute position when loading it full of snow.
Personally I'm ok with some squeak which is not heard when the engine is running.
liftoff1967 is offline
post #7 of 9 Old 09-29-2015, 09:04 PM
I just came back from HD and both a Deluxe 28 and one of the Compact 24's made the same squeaking noise like in the above video. These guys are missing something in assembly. The noise is definitely coming from the gear box attached to the Ice Drill and not from the bottom of the discharge shoot.
sony1998 is offline
post #8 of 9 Old 09-30-2015, 07:20 AM
Likes (Received): 1379
They more than likely forgot the lube.
post #9 of 9 Old 09-30-2015, 12:43 PM
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
I looked at the assembly instructions online, the first instruction is to grease the discharge chute. "Grease underside of discharge chute ring. (if not already greased) Guess the big box boys figure it's greased or are all out of grease.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
