I just acquired a 70s 10995 Ariens today! With a Craker-Jack prize! - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 09-13-2015, 02:46 AM Thread Starter
Thanks (Given): 31
Thanks (Received): 15
Likes (Given): 67
Likes (Received): 16
I just acquired a 70s Ariens today! IT seems to be in good shape considering being left outside in the elements for a number of years! One Good thing it has great compression! Previous owner mentioned it worked well last time he used it.
I would like to know the correct steps in trying to bring this back to life. I can take care of the scraper bar and the mechanics of the moving parts and cables (which seem to all work OK).However I would like to approach in the correct procedures, what I should or shouldn't do, to avoid causing regrettable damage. Do I need take apart the carb, any seals to replace? I will change the oil although itís proper level and in good condition! Anything to PRE-check on the drive or special lubes locations? The augers and impeller seem to be greased and rotate well. Model #10995 Serial #004121
OH I also got a bonus Craftsman chainsaw!
ID:	55986   Click image for larger version
ID:	55994   Click image for larger version
ID:	56002   Click image for larger version
ID:	56010   Click image for larger version
Ariens Deluxe28+ AX414cc
Ariens ST824
Ariens 1970
Honda HS521
Cub cadet SS
Snowbird
Biketrax is offline
post #2 of 16 Old 09-13-2015, 08:09 AM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1029
Looks to be in pretty decent shape for its age. Nice score.
There'll be someone come along and give you sound advice. I'm not familiar with these.
post #3 of 16 Old 09-13-2015, 08:50 AM
Thanks (Given): 587
Thanks (Received): 769
Likes (Given): 4352
Likes (Received): 1734
Nice score. Is that the number off the impeller housing as the "Tractor" will have a separate model and serial number too.
You new favorite web site for all things Ariens: The Ariens 1960's and 1970's Sno-Thro info site.
Is there a faint chance you're missing a "9" at the beginning of that model number ??
910995 - 24" Sno-Thro attachment - (1970 - 1971 - 1972 - 1973)
Likes Biketrax liked this post
post #4 of 16 Old 09-13-2015, 09:23 AM
Likes (Received): 303
K$frog, I was wondering the same thing or if he actually got the attachment number as the model number. I thought the '69 was the last tractor to have that style chute gear hookup (not on the side, but under the ring gear and more midline). Shame it was left out to rust up as it looks to be lightly used and the skids look original. Can't see the left handlebar grip to see if it has the pin lock.
post #5 of 16 Old 09-13-2015, 10:16 AM
Thanks (Given): 14
Likes (Given): 44
Likes (Received): 50
Sweet score! The pic with it in the truck shows that one of the clutch handles is engaged, so if it starts and is in gear it's moving, so push that down, if u take off the belt cover you will see how simple the whole thing is. I'd hold off on the oil until I knew it ran. I'd remove the carb cover, hook up a aux gas tank, spray in some starter fluid and see if she blows some smoke!
I've had two craftsmans then I aquired one of these era ariens, great machine, truly heavy duty, look at the gauge steel, I ended up with a hf engine and impeller kit and I'm very happy with it.
Rob
Rob711 is offline
post #6 of 16 Old 09-13-2015, 11:19 AM
db130's Avatar
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
Is there any gummed up gas in the gas tank that smells like varnish? You may have to drain the gas/replace the fuel line/clean the carb.
I picked up a similar unit this weekend that hadn't been started in "over a year" - I got it to run after draining the tank and cleaning out the main jet and the fuel bowl, but it runs lean right now and I'll probably need to clean out the carb better.
db130 is offline
post #7 of 16 Old 09-13-2015, 11:51 AM
Grunt's Avatar
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3334
Likes (Received): 679
Hello Biketrax, nice machine. In addition to all the great advice given, I also would try getting it running as is and proceed as necessary. I would check the gas tank for rust and add a fuel filter to prevent rust from entering the carb. You may want to rebuild or if necessary, replace the carb, change spark plug, check and replace the belts, perform a compression or leak down test to give an idea of general engine condition.
That black knob sticking out of the heater box is what I call a mechanical primer. I leave the ignition off, push and hold that knob in tightly and pull the recoil rope a few times to prime the motor and release the knob. Turn ignition on, choke to closed position and try to start the motor. Sorry if you already knew it's function.
post #8 of 16 Old 09-13-2015, 12:46 PM
loneraider's Avatar
Thanks (Received): 14
Likes (Received): 15
Thumbs up
I picked up a 75 model that was sitting outside for a couple of years and I can tell you the gas and carb were in rough shape. I think if you change out the fuel & pull the float bowel off unscrew that main jet and give it a good clean especially those tiny holes uptop she should run.
Don't forget she wont fire unless the drive is dis engaged, the lever on the right hand side.
Looks like its a good candidate for a restore.
I just finished my bucket restore on a 922003 and I had to replace the
bearing on the shaft as it was toast. Getting the sheave off to replace the bearing was not fun to say the least.lol
If your doing a repaint chevy orange DE 1620 is the color match.
Ariens deluxe 28
Ariens 927le
ariens self propelled mower
loneraider is offline
Thanks Biketrax thanked for this post
post #9 of 16 Old 09-13-2015, 03:57 PM
Thanks (Given): 14
Likes (Given): 44
It will if the engine is in good shape, that's why these are so fun, you could pull the cord and it's off and running on it's own!
Rob711 is offline
post #10 of 16 Old 09-16-2015, 12:05 AM Thread Starter
Thanks (Given): 31
Likes (Given): 67
Kiss4 I have visited that Ariens site before and refreshed myself thanks! IT sure makes for better reading and understanding when you own one!
To answer some questions:
No gas in the tank and looks clean.
No preceding number! And no other numbers on the machine.
Yes there is a pin lock on the left handle.
I have cleaned the bowl, which was dirty.
Will proceed soon, just a bit busy these days
Will keep you posted
Thanks for all the great information and help!
Ariens ST824
Ariens 1970
Honda HS521
Cub cadet SS
Snowbird
Biketrax is offline
