Help with a Deluxe 28 Part Number - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 09-17-2015, 03:33 PM Thread Starter
I reviewed the parts manual for my Ariens Deluxe 28 model #921022 and could find anything. Does anybody know a part number for this piece of black rubber that protects the end of the cable that attached to the chute? As you can see, mine is split in half. Is this something to worry about? Do I have to buy the whole cable assembly for the piece I need? Thanks.
White Out is offline
post #2 of 11 Old 09-17-2015, 05:05 PM
Likes (Received): 1378
NO you need not worry about that. it is more for looking cool than anything else.
post #3 of 11 Old 09-17-2015, 05:12 PM
Thanks (Received): 14
Likes (Received): 15
Smile
You could glue that together rather easily with gorilla glue or something similar. I guess its there to protect the cable from the elements ,rusting & maybe freezing up.
You know what they say: Duct tape saves the world but I think some glue
would look a lot better!
Ariens deluxe 28
Ariens 927le
ariens self propelled mower
loneraider is offline
post #4 of 11 Old 09-17-2015, 06:34 PM
Thanks (Given): 31
Thanks (Received): 15
Likes (Given): 67
Likes (Received): 16
I would trade the machine in and upgrade!!
Use some crazy glue.
And go have a cold refreshing beverage!!
Ariens Deluxe28+ AX414cc
Ariens ST824
Ariens 1970
Honda HS521
Cub cadet SS
Snowbird
Biketrax is offline
post #5 of 11 Old 09-17-2015, 09:20 PM
I don't know if it is possible with yours, but I know Ariens flipped the assembly upside down and has the cable coming in from the top now. This prevents water from going down the cable.
post #6 of 11 Old 09-18-2015, 05:29 PM
you could use electrical tape. also. it should be a stainless steel cable. other than that I would not lose any sleep over it.
post #7 of 11 Old 09-18-2015, 07:54 PM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
Need the model and serial number to find some parts.
post #8 of 11 Old 09-18-2015, 08:03 PM
Thanks (Given): 588
Likes (Given): 4353
Need the serial number to check the Ariens site but the generic sites seem to sell it only as an assembly.
$32 Ariens Snowblower Control Cable 06900406 Order now for same day shipping. 365 day return policy. RepairClinic.com
post #9 of 11 Old 09-19-2015, 08:45 AM
Likes (Received): 8
That should work good.
AndyW is offline
post #10 of 11 Old 09-19-2015, 09:29 AM
Thanks (Given): 588
Likes (Given): 4353
Electrical tape ?? IMHO that wouldn't even make it through summer with the adhesive melting and turning to goo. In the winter once it got cold it would just crack up and fall off. It's not designed to handle much heat and no movement.
Some of the generic boots would be a much better choice
https://jet.com/product/product/f575...FQiNaQodJUQKHg
Shift Cable Bellows - Sierra 18-2753-2D - iboats.com
