AX306 rpm - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 09-24-2015, 07:38 AM Thread Starter
AX306 rpm
Just took delivery of my Deluxe 28 SHO and I installed a mini-tach device to track engine hours (AX306). One of the features is to display rpm and the tach shows 3450 rpm at full throttle which is lower than the rated 3850 +- 50 stated in the LCT literature. Has anyone measured rpm on the AX306?
mrsteve7 is offline
post #2 of 11 Old 09-24-2015, 07:57 AM
Thanks (Received): 41
Likes (Received): 98
Seems low to me, even the old tec's and briggs ran at 3600.
Ask the dealer, if you bought from one or contact Ariens.
Post up what you find.
scrappy is offline
Likes Elt31987 liked this post
post #3 of 11 Old 09-24-2015, 11:41 AM
Thanks (Given): 31
Thanks (Received): 15
Likes (Given): 67
Likes (Received): 16
Interested in the hook up!
Could you post a diagram or some pictures?
thanks
Ariens Deluxe28+ AX414cc
Ariens ST824
Ariens 1970
Honda HS521
Cub cadet SS
Snowbird
Biketrax is offline
post #4 of 11 Old 09-24-2015, 12:23 PM
guilateen02's Avatar
Thanks (Received): 30
Likes (Received): 110
I've found that many engines I've tested rarely ran at max throttle. Maybe the manufacturing company doesn't set it at max for longevity.Also for smoothness and pleasurable operating. Most consumers don't won't a screaming engine. My Tecumseh 8 hp was running at 3200. They don't think there's nut jobs like us out there that will hook up a tach to it. As long as it sounds good everything is Kosher right, not. Also at what RPM is max torque? I believe some LCT is max Torque at 3400 to 3575.
guilateen02 is offline
post #5 of 11 Old 09-24-2015, 01:43 PM
Likes (Received): 303
I'd start with hooking up the tach to a lawnmower or other small engine and see what numbers it throws out. Start at the basics and move up. Nothing wrong with doubting the builder, but prove the level first.
post #6 of 11 Old 09-24-2015, 09:36 PM Thread Starter
Good point. I intend to do just that.
mrsteve7 is offline
post #7 of 11 Old 09-24-2015, 09:38 PM Thread Starter
thanks
The tach has a single two-foot length of wire. The end is wrapped around the spark plug wire 4-5 turns and taped in place. Simple as that.
mrsteve7 is offline
post #8 of 11 Old 09-24-2015, 10:03 PM
thanks
If you have a DVOM that reads frequency, you can use it to read RPMs.
Just remember small engines fire every revolution (waste spark)
Use a Multimeter to Read RPM - DIY Tach
scrappy is offline
post #9 of 11 Old 09-25-2015, 06:55 AM Thread Starter
Great suggestion - thanks
mrsteve7 is offline
post #10 of 11 Old 09-25-2015, 10:35 AM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1741
How to install one of the hour meter/tachs.
I have them on my riders.
