Path-Pro SS21E or SS21EC - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 10-05-2015, 10:50 AM Thread Starter
Hi, I'm completely new to snow blowers unless you count my shovel collection Due to the amount of snow we got here in Chicago area the past couple winters along with getting older I'm thinking about getting a mechanical shovel.
Home Depot has couple models listed and looking at the product details pages and compare between the two, all the specs listed are the same except the model number and price deference of $100 and the EC weights 3 lb more.
Any idea what are the differences between SS21E and SS21EC ?
dariusf is offline
post #2 of 13 Old 10-05-2015, 11:06 AM
Likes (Received): 1379
I just looked at HD'S web site on those. out side of the hundred bucks. they look the same to me. ALOHA from the paradise city.
post #3 of 13 Old 10-05-2015, 11:06 AM
Thanks (Given): 72
Thanks (Received): 397
Likes (Given): 182
Likes (Received): 931
It looks like SS21E and SS21EC might be Home Depot's own internal numbers..
I cant find those actual numbers used anywhere except Home Depot..and Ariens doesnt seem to actually use them..but thats ok! because Home Depot does list the actual model numbers:
SS21E = Model 938032 = Ariens calls it "Path Pro 280E"
SS21EC = Model 938033 = Ariens calls it "Path Pro 280EC"
download the Ariens spec sheet here:
http://www.ariens.com/en-us/Documents/Spec_PathPro.pdf
the only difference is the EC has a remote chute rotator, (and as a result, its 10 pounds heavier) while the E has a manual chute..everything else looks identical.
post #4 of 13 Old 10-05-2015, 11:12 AM
Thanks (Given): 102
Likes (Given): 273
Darius, welcome aboard!
I've got the bottom of the line 21" Path Pro. It's an outstanding performer.
uberT is offline
post #5 of 13 Old 10-05-2015, 12:03 PM Thread Starter
Thank you all, appreciate the feedback and help. Remote chute rotator? Is it running of a sensor with a camera like the Mercedes Active Drive, detecting the objects in range and rotating the chute away?
Is this worth $100 premium?
dariusf is offline
post #6 of 13 Old 10-05-2015, 12:25 PM
Thanks (Given): 102
Likes (Given): 273
I thought the retro fit kit was $80 or so? I was going to add it to mine but never did.
Not having it may or may not be an issue. How's that for being decisive
I tend to run for a quite a distance before needing the change the chute direction - - our drive is fairly long. If the area you are cleaning is small/more confined, I suppose you'd change chute direction more often and some will prefer having the remote control.
uberT is offline
post #7 of 13 Old 10-05-2015, 12:31 PM Thread Starter
by remote control I assume you mean some mechanical contraption next by the hanle bar which will let me move the chute? The pic shows a handle around the chute which I guess I could band over and use I think I will save the $100 and get the lower cost one. Thanks!
dariusf is offline
post #8 of 13 Old 10-05-2015, 12:38 PM Thread Starter
dariusf is offline
post #9 of 13 Old 10-05-2015, 05:16 PM
Thanks (Given): 102
Likes (Given): 273
There you go! That's a good deal!
uberT is offline
post #10 of 13 Old 10-05-2015, 08:00 PM
liftoff1967's Avatar
Thanks (Given): 36
Thanks (Received): 45
Likes (Given): 65
Likes (Received): 94
I did add the remote chute kit thingie. It was a little bit of a challenge getting a self tapping screw to bite while gravity is working against ya. Once that screw took hold it was a pretty easy install. Well worth the $80 the local Ariens shop took from my wallet in exchange.
liftoff1967 is offline
