Trouble identifying my old ariens - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 10-15-2015, 05:44 PM Thread Starter
Hey group! I have been scouring this forum trying to figure out what machine I have. I picked this baby up for 40 bucks at a swap meet this spring. It runs in choke and needs a new carb. I also wanted to put new belts on it. Unfortunately the local ariens dealer will not help me without the Tecumseh number. I cannot find the number because I think the shroud was replaced. Can anyone help me out?
ID:	59042   Click image for larger version
ID:	59050   Click image for larger version
ID:	59058   Click image for larger version
Justinf is offline
post #2 of 14 Old 10-15-2015, 06:25 PM
70s. Looks like you can almost read the model and serial numbers. See where it's stamped in there in the metal. If you Polish that with a Dremel and some Polish you should be able to read it. Or try some very fine sandpaper and wetsand very light till you can read it. Like 2000 grit. Shouldn't be to hard for someone here to figure the year out. My numbers on mine are all gone I got nothing
bubbs16 is offline
post #3 of 14 Old 10-15-2015, 07:14 PM
Thanks (Given): 590
Likes (Given): 4368
Likes (Received): 1743
Welcome to the forum Justinf
Maybe with a magnifier and a flashlight. Using the flashlight at different angles sometimes helps.
If you haven't linked to this site now's the time. Best friend for anyone with an old Ariens.
The Ariens 1960's and 1970's Sno-Thro info site..
Sscotsman is the Ariens expert. Snowblower Forum : Snow Blower Forums - View Profile: sscotsman
Looks like it's likely a 22,000 series 1969-1978 Page 6 on the web site.
Can you make out the numbers on the snow blower, on the impeller housing ??
BUT ... you're interested in the engine numbers. The other thing to do is get down to the carb and see what numbers are on the carb itself and just use those to get a rebuild kit or a replacement carb.
post #4 of 14 Old 10-15-2015, 10:00 PM
Thanks (Given): 72
Thanks (Received): 397
Likes (Given): 182
Likes (Received): 931
95% likely to be a 1971-1972 model 922002.
Justin, there is also a data tag on the side of the scoop..please post those numbers. and also look round the engine for a Tecumseh data tag, and post any numbers you find there too..
sscotsman is offline
post #5 of 14 Old 10-16-2015, 03:28 PM Thread Starter
Scott I am pretty positive that the number is 922002 also but the engine I cannot find any tag on it. The cover that the recoil attaches to I am pretty sure has been replaced. It has also had a head gasket job. I can get the numbers off the carb but do you know what model engine is probably on this unit? I can take some more photos of the engine when I get home if that helps
Justinf is offline
post #6 of 14 Old 10-16-2015, 04:24 PM Thread Starter
Here are some more photos. Sanded away the paint for the model number. 92200? I think the last number is a 2?
ID:	59138   Click image for larger version
ID:	59146   Click image for larger version
ID:	59154   Click image for larger version
ID:	59162   Click image for larger version
ID:	59178   Click image for larger version
Justinf is offline
post #7 of 14 Old 10-17-2015, 11:25 PM
Thanks (Given): 33
Thanks (Received): 37
Likes (Given): 64
Likes (Received): 87
Well it seems you have a perfectly clear photo there of a tag showing model number as 922003, so that pretty much confirms what Scot had said about model year.
2015 Ariens Deluxe 28+ 921037, 414cc LCT (now son's)
2014 Ariens Platinum 30 921029, 414cc LCT (mine forever)
PixMan is offline
post #8 of 14 Old 10-18-2015, 10:16 AM
Thanks (Given): 10
Thanks (Received): 19
Likes (Given): 9
Likes (Received): 59
Pickup a new muffler while your there.
Just needs a little TLC.
You going to paint it sometime?
I wonder if the recoil needs some work?
The pull rope seems to be too far out?
I hate shoveling SNOW!
22" Dual Stage
"Classic" 1963 S-226 Snowbird
22" Dual Stage
Big Ed is offline
post #9 of 14 Old 10-18-2015, 10:35 AM
Thanks (Given): 72
Likes (Given): 182
Going by the number on the tractor tag, the one that is quite faded, it could be model 922002 or 922022. (the last digit is clearly 2, but the digits in the middle are unclear.)
922002 is from 1971/1972.
922022 is from 1976/77/78.
The tractor tag, scoop attachment model 922003, now makes it 100% clear the snowblower is model 922002! because scoop 922003 would go with snowblower 922002, but it wouldnt go with 922022.
The scoop has a low serial number:
model 922003.
serial 009004.
The Ariens chart:
Says that serial number goes with 1971/1972..
So case closed..this is a 1971/1972 model 922002, with a 1971/1972 model 922003 scoop..the dates match.
Now, why did Ariens say "1971/1972" instead of only model year?
we dont know..
I suspect its because that chart was made in 1978, at the end of the 22,000 series run, and they couldnt find the specific details to differentiate between 1971 and 1972 exactly..that has happened with the 10,000 series as well..
There is only one thing that could determine the exact model year, 1971 or 1972, and that would be the Tecumseh data tag..which appears to be missing..
but we can do a bit more sleuthing..
the scoop attachment 922003 was made 1971 to 1975..
1971 and 1972 (two model years) is serial numbers 00001 to 010599 = 10,000 units for the two years.
1973 = 15,000 units
1974 = 8,000 units
1975 = 7,000 units
So we have a known serial number of 009004, the 9,000th unit out of 10,000 for the two-year 1971/1972 run..so which year is more likely? '71 or '72? obviously its 1972.
So, IMO its very clear..its a 1972 model 922002.
Thanks Justinf thanked for this post
post #10 of 14 Old 10-18-2015, 10:38 AM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3354
Likes (Received): 679
Hello Justinf. I can not open the 22000 series parts manuals on Scot's page to confirm my findings, but this is the closest info for your engine that "I" could find. Hopefuly Scot can find the actual engine numbers for you.
Carb 631794 (casting number 1241)
http://www.partstree.com/parts/tecumseh/carburetors/631794a-tecumseh-carburetor/carburetor/
Carb rebuild kit-
http://www.repairclinic.com/Shop-For-Parts/a22b329c102d790325/Model-CA631794A-Tecumseh-Small-Engine-Carburetor-Parts
Engine parts list (possibly?) Engine numbers HS40-55440D/E, HS40-55455D, HS40-55510E (The carb on this engine list does not match the 631794 carb above)
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-HS40-55455D-PARTS-LIST.pdf
Likes Justinf liked this post
