model 921044 carburetor question - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 10-16-2015, 12:14 PM Thread Starter
i have a new ariens model 921044 snow blower with a LCT engine that I am just becoming familiar with.
I see that there are two 10mm screws in the bottom of the carburetor bowl. please, which of these is the drain screw for the bowl ?
garthman
garthman is offline
post #2 of 4 Old 10-16-2015, 01:12 PM
With Honda clone carbs, the bottom one that is flat removes the bowl, the one on the side on an angle is the drain. I am not sure how much fuel remains in the bowl after you drain it, but I suppose you could tip the machine back to get the rest out.
Typically they have a sediment cup as well. That is basically a smaller bowl before the main bowl for catching dirt. That has the nut molded directly in to the end of it and can also be unscrewed for cleaning.
http://outdoorpowerinfo.com/repairs/...00-zf6-w10.asp
post #3 of 4 Old 10-16-2015, 04:29 PM Thread Starter
carburetor screws
thanks
i didn't see a second sediment bowl, but then i wasn't looking for one; i'll look for it next time i get the machine out
garthman is offline
post #4 of 4 Old 10-16-2015, 05:49 PM
i usually just remove the main bowl nut because it gets every drop of gas out. some clones dont have sediment cups
