New pro 28 - Snowblower Forum : Snow Blower Forums
post #1 of 28 Old 10-24-2015, 09:28 PM Thread Starter
New pro 28
Just got my first snow blower delivered, a pro 28 disc drive.
I was just messing around with it in my garage...no snow yet... When the chute deflector is put in the down position it goes down nicely, however, when I put it in the UP position it doesn't spring back. If I give it a little assistance it will spring back. Is there something that needs to be adjusted?
Thank you and sorry for the newbie question
Jewcati is offline
Thanks bwdbrn1 thanked for this post
post #2 of 28 Old 10-24-2015, 10:00 PM
Likes (Received): 82
Welcome to the forum ,there is an adjustment on the side of the chute deflector.
Give it a try to tighten the spring and try to lube each side of the deflector.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 28 Old 10-24-2015, 10:55 PM
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
Congrats on your new Ariens Pro 28 that is a serious machine. I would try the adjustment Normex recommended if that doesn't work I would call the dealer, he should have tested it before delivery. Best of luck with it.
Cardo111 is offline
post #4 of 28 Old 10-25-2015, 08:19 AM
Thanks (Received): 238
Likes (Received): 608
Welcome to SBF. No problem at all with your newbie question, that's what we're here for. Hope to hear from you often as you get to use your new snow blower.
post #5 of 28 Old 10-25-2015, 09:00 AM
Thanks (Given): 589
Likes (Given): 4362
Likes (Received): 1741
Welcome to the forum Jewcati
Very nice choice for a first machine
post #6 of 28 Old 10-25-2015, 11:33 AM
Thanks (Received): 28
Likes (Received): 107
Welcome to the forum and congrats on that machine. Hopefully that problem is an easy fix with just a simple adjustment. I will be eager to hear your comments on that machine...
Kielbasa is online now
post #7 of 28 Old 10-25-2015, 01:36 PM
Likes (Given): 21
Likes (Received): 25
It is probably dragging on the sheet metal chute,look for scrape marks on the side of the chute.I had to bend in one I had
2018 Ariens 938025 Professional 21 inch
2018 Ariens 921050 Platinum 369cc SHO 24"
2011 John Deere X728/47" Quick Hitch Snowblower
Life is too short to sweat the petty stuff
vmaxed is offline
post #8 of 28 Old 10-25-2015, 11:06 PM
Thanks (Given): 66
Thanks (Received): 123
Likes (Given): 114
Likes (Received): 157
I expect the cable attaches to the deflector and is anchored to the chute. This design is sensitive to the tightness of the cable attachment nut on the deflector. Try loosening the nut a little so the cable can pivot freely.
The spring seems to have little mechanical advantage so all other parts must operate freely to compensate for the weak spring force. You can increase the spring force a little by mounting a washer on the shaft to preload the spring. I did it to my machine but it is a potch to do.
Cable routing is important to avoid friction from tight curves affecting the deflector return.
Good luck.
Town is online now
post #9 of 28 Old 10-25-2015, 11:41 PM
Likes (Received): 24
I find mine does this when the weather is warm. I guess it expands the metal a bit and there is a bit of rub. In the cold it does not. Even if it did, the second there is snow going out the chute it will open...
Ariens Platinum 30
Stuofsci02 is offline
post #10 of 28 Old 10-26-2015, 12:15 AM
I did the same but added a lock nut approx. 3/8" thick to increase preloading pressure and it works in summer and winter like it's suppose to.
Normex is offline
Likes Town liked this post
