Ariens direct swapout engine replacement - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 10-28-2015, 11:17 AM Thread Starter
Thanks (Given): 49
Thanks (Received): 8
Likes (Received): 7
I have an Ariens 7 hp model 924028 008001 ST724 I think it was new in 1978. What is a good direct bolt on engine replacement, one that does not require a whole reconfiguration of the workings and is suitable as not to over power the transmission or blower assembly?
ron3033 is offline
post #2 of 19 Old 10-28-2015, 11:54 AM
harb or freight predator 212cc
Thanks ron3033 thanked for this post
post #3 of 19 Old 10-28-2015, 01:29 PM
Predator should work well for you. Frequently on sale for $99.
post #4 of 19 Old 11-01-2015, 02:57 PM
Harbor Freight 420 cc
I see the 212cc 5hp recommended alot. Has anyone put on the 420 cc 13hp model? Is the installation similar to the 212cc model?
bpahlm79 is offline
post #5 of 19 Old 11-02-2015, 03:12 PM Thread Starter
Thanks (Given): 49
Likes (Received): 7
Thank you all.
Will a 5 HP be enough go since it is replacing a 7 HP? We do get a lot of snow here most winters.
Thanks ron3033
ron3033 is offline
post #6 of 19 Old 11-02-2015, 03:23 PM Thread Starter
Thanks (Given): 49
Likes (Received): 7
Shryp
Is the snow blower in your avatar like my Ariens 7 hp model 924028 008001 ST724 I think it was new in 1978...... with the predator 212cc engine on it?
Thanks ron3033
ron3033 is offline
post #7 of 19 Old 11-02-2015, 03:27 PM
I have a late 1970s and an early 1980s with Predator engines on them and they both run great. They were originally 8 and 7 HP and now have 212cc engines on them. Plenty of power.
Here is the 1980s model:
http://cleveland.craigslist.org/grd/5279080661.html
Found the one from my avatar as well:
https://www.snowblowerforum.com/forum...my-blower.html
Also, the 212cc is more like 7 HP. The 196cc Hondas are usually marketed as 6.5 HP. People who use the 212cc engine say it has more power then their worn out 8 HP engines. Granted an old engine compared to a new one isn't quite fair.
Also, the Predator has a $99 coupon that is active right now. Expires 11/30/15.
Thanks ron3033, Bordak thanked for this post
post #8 of 19 Old 11-03-2015, 04:40 PM Thread Starter
Thanks (Given): 49
Likes (Received): 7
Thank You Shryp Great info Thanks ron3033
ron3033 is offline
post #9 of 19 Old 11-03-2015, 04:44 PM Thread Starter
Thanks (Given): 49
Likes (Received): 7
Thanks Shryp, Great info ron3033
ron3033 is offline
post #10 of 19 Old 11-04-2015, 04:28 PM
Likes (Received): 12
I did the 420cc swap on my Ariens. Being a larger motor than stock, I had to make a new mounting plate to bolt the motor to. Also a new pulley and belt were needed. Check out my thread if you want to see what I did...32inch Ariens Restoration and Repower
1971 Ariens 7/24 (retired)
2011 Ariens Deluxe 24
1980 Ariens st7/24 (retired)
1985 Ariens st10/36
SlowRider22 is offline
Likes bpahlm79, ron3033 liked this post
