List of routine lubrication points - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 10-28-2015, 08:55 PM Thread Starter
I was hoping to get some input on forming a list of areas that should be greased as a part of routine maintenance to keep things running in good condition.
What spots should be greased/re-greased during the season and between seasons?
2013 Ariens P24
TheHolyCannoli is offline
post #2 of 7 Old 10-28-2015, 09:32 PM
Thanks (Received): 7
Likes (Given): 18
Likes (Received): 8
Here's good previous thread to check out - Mx THREAD
PolarNorth is offline
post #3 of 7 Old 10-28-2015, 11:31 PM
Thanks (Given): 33
Thanks (Received): 14
Likes (Given): 21
Likes (Received): 19
Unless the owners manual indicates areas to use grease or the like I just use silicone spray a couple times a year as it doesn't attract dirt. Anything and everything that pivots or slides gets a shot. I also removed the wheels and gave each axle a coat of anti-seize.
BullFrog is offline
post #4 of 7 Old 10-29-2015, 07:30 AM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
Anti-seize is nice in places that have a tight fit like a screw or bolt and it's threaded hole but in places where there's clearance like things that slip fit it dries up and flakes out. Grease would be a better and longer lasting choice.
Good idea to lube/protect anything that moves.
post #5 of 7 Old 10-29-2015, 07:41 AM
Thanks (Given): 33
Likes (Given): 21
Thanks for the anti-seize tip. I'll keep an eye on it.
BullFrog is offline
post #6 of 7 Old 10-29-2015, 08:39 AM
Thanks (Received): 33
Likes (Received): 54
I don't like the use of Silicone for a snowblower chute/bucket or anywhere where you might get overspray to these areas. Reason being, I like to touch up any nicks, etc at end of season. Silicone/paint don't play well.
mobiledynamics is offline
post #7 of 7 Old 10-29-2015, 10:03 AM
Thanks (Given): 33
Likes (Given): 21
No they don't. I guess it depends on what conditions the blower is used in. I can see that if you need to do touch ups silicone would be an issue but I only go through snow. If and when the city comes by they always remove the snow at the end of the driveway so it's never in any gravel and salt kind of mix. The old blower was 20 to 25 years old and still had great paint on it. Nothing at all like some of the photos I've seen on here. I guess the bottom line is use what you think is appropriate for how your machine is going to be used.
BullFrog is offline
