AX306 Drain Plug Thread Size? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 10-29-2015, 05:04 PM Thread Starter
Likes (Received): 18
Hello,
Does anyone happen to know the thread size on the drain plug used on the AX306 engine?
The link below shows the drain plug on the drain tube (#55 in the diagram) behind the engine, but LCT does not list the thread size.
LCT PW8HK17950781DEABGILOQTUVX59E1M (930670204) Parts Diagrams for Parts Assembly
Thanks!
Vento is offline
post #2 of 8 Old 10-29-2015, 07:07 PM
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
Originally Posted by Vento View Post
Hello,
Thanks!
I am pretty sure it is 12mm X 1.5mm thread pitch.
Cardo111 is offline
post #3 of 8 Old 10-30-2015, 06:59 AM
Likes (Received): 1379
it is either a 10mm or 12mm. there is a thread on that 1. that I started.
post #4 of 8 Old 10-30-2015, 04:42 PM Thread Starter
Thank you, but I think you guys are talking about the thread for the bolt shown in the diagram as #49. My engine has the drain in the back (#55) instead of on the sides and they used a cap to block it off. I know for sure it isn't a 10 or 12 mm as that's too small.
Thanks!
Vento is offline
post #5 of 8 Old 10-30-2015, 10:55 PM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
From the diagram, the back mounted oil drain with a cap does not show a sealing washer. I would assume it is a tapered pipe thread.
Otherwise, Based on this information it is listed as a m12 x 1.5 thread. I hope this helps!
Oil Drain Plug for Honda GC135 GC120 GC160 GX120 Engines Lawn Mowers Generators | eBay
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #6 of 8 Old 10-30-2015, 11:13 PM
Likes (Received): 82
Vento it could very much be a 12mm bolt size but for the life of me why don't you try to call LCT and hear from the horses mouth and share the findings with us. Thank You and Good Luck
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #7 of 8 Old 10-31-2015, 05:17 AM
Thanks!
post pic so I can have a looksee. they are all pipe threads.
post #8 of 8 Old 10-31-2015, 12:22 PM
Thanks (Given): 589
Likes (Given): 4364
Likes (Received): 1742
When it's time to drain the oil take it off and bring it with you to a hardware or big box store and try some fittings. From the parts diagram it would appear to be a pipe thread and it's NLA on Ariens site.
