Deluxe 28 Headlight problem - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 11-02-2015, 12:20 PM Thread Starter
Hi Everyone,
I have a Deluxe 28, a few years old. The headlight stopped working. I put a simple circuit tester on the wires coming out of the engine area and got nothing (didn't light up).
Are there instructions anywhere on how to get to where those wires originate and fix?
GeorgeT is offline
post #2 of 15 Old 11-02-2015, 03:24 PM
Thanks (Received): 112
Likes (Received): 298
Originally Posted by GeorgeT View Post
Hi Everyone,
Did you check the bulb?
skutflut is offline
post #3 of 15 Old 11-02-2015, 03:58 PM Thread Starter
The bulb works fine. Just not getting any juice! Very frustrating.
GeorgeT is offline
post #4 of 15 Old 11-02-2015, 04:57 PM
Likes (Received): 62
The wire comes off the stator. To get to the stator you have to remove the engine shroud and pull off the flywheel. To get the flywheel off,you may need a gear puller. The stator should be mounted to the external wall of the engine, visible once the flywheel is removed. Getting to the stator can sometimes be challenging if the flywheel is rusted in place. If you don't have a gear puller, borrow one (with a deposit you may get a loaner from Auto Zone). Once you get the flywheel off, removing the stator is easy. I'm not "Super Mechanic" but it's not really bad as long as you take your time and have the right tools (gear puller). Check YouTube for a video (start with donyboy73).
I had a similar problem with a Tecumseh engine. When I got the flywheel off, there was no stator (or so it seemed). Weird experience but the stator must have loosened. The magnets inside the flywheel rotate past the stator and generate the electricity. Once the stator loosened, the magnets must have ripped it off the wall of the engine. I found it inside the flywheel held in place by the magnet in the stator.
Before you go to all of that work, follow the wires as far as you can and look for wire damage (melting from engine heat, chewing by mice, etc.). If so, you might just need to splice the wire.
Let me know if that makes sense. If you need more help, I have pictures that I can upload later that walks you through it step-by-step.
CO Snow is online now
Likes Grunt liked this post
post #5 of 15 Old 11-02-2015, 09:07 PM
GeorgeT, if you do start the process to remove the flywheel to check the stator, here's the link to the discussion when I was dealing with mine. It includes photos of the process.
https://www.snowblowerforum.com/forum...re-stator.html
post #6 of 15 Old 11-03-2015, 12:45 AM
kwk11's Avatar
If it's a few years old, it should be under warranty, no?
2015 24" Platinum SHO
kwk11 is offline
post #7 of 15 Old 11-03-2015, 06:10 AM
Warranties are great and give you a warm fuzzy feeling...that is until you bring it to the dealer and it takes them over a month to fix it because they're backed up. Not exactly the time of year to be without your snowblower for a month or longer.
djc11369 is offline
post #8 of 15 Old 11-03-2015, 06:36 AM
kwk11's Avatar
A month, if your dealer takes that long I feel sorry for you.
If the engine needs to be disassembled to fix the headlight issue, I think I would take it to the dealer.
kwk11 is offline
post #9 of 15 Old 11-03-2015, 03:31 PM Thread Starter
thank you!
these are great suggestions! i'll inspect the wires closely to ensure there's no breakage. not looking forward to getting behind the flywheel. I'll have to order the stator first so that i'm ready to replace it if necessary.
GeorgeT is offline
post #10 of 15 Old 11-03-2015, 03:49 PM
Thanks (Received): 379
Likes (Received): 1377
The wires might have broken or rotted away inside their protective covering. juts tossing that 1 out there also.
