Headlight/Handwarmers Issue... - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 11-08-2015, 05:47 PM Thread Starter
Hi,
I have an Ariens ST1028SLE (Model 924109) with a Tecumseh 10hp Engine (Model HMSK100). I just purchased a heated hand grip kit from Ariens (part # 72100800) and have installed it successfully. The issue I'm having is that when I have the handwarmers on, the Ariens stock headlight (part # 02478100) dims way down. I'm imagining because between the handwarmers and the incandescent light bulb that it's too much for the alternator. My solution was to replace the incandescent bulb with an LED bulb which requires far less wattage to run. So far, the two 1141 bulb LED replacements that I've tried have blown out a minute after running whether the handwarmers are running or not. Does anyone have a solution for this issue?
The other question I have is whether the handwarmers are AC or DC? I'm guessing DC, but I haven't found anything from Ariens leaning one way or the other. I just want to be 100% positive that the light and handwarmers can function on the same power.
Also, if the alternator can't support both the headlight and the handwarmers at the same time, does anyone have a solution for supporting both?
Thanks in advance for any and all thoughts!!!
-Scott
news82 is offline
post #2 of 14 Old 11-08-2015, 07:14 PM
Thanks (Given): 587
Thanks (Received): 769
Likes (Given): 4352
Likes (Received): 1734
The LEDs require far less amperage to run. Amps are what you are lacking from the electrical system.
The hand warmers don't care if it's AC or DC and it's possible you have AC and DC since it didn't come with LEDs and AC is what the system produces. They have to add ( more $$$) to convert AC to DC so as it's cheaper, it's likely AC. The other thing is without a regulator like needed on a riding mower with a battery to maintain 12-14 volts you engine is likely running up around 18-24 volts ??
Depending on the LEDs, they may not handle that much voltage or the AC might be knocking them out.
EXACTLY ... what 1141 replacements are you using ??
What is the full model number of the engine. That should tell us what amperage it's capable of producing.
Do the hand warmers get hot ??
post #3 of 14 Old 11-08-2015, 07:18 PM
Thanks (Given): 587
Likes (Given): 4352
Sorry, Welcome to the forum
This might help : https://www.snowblowerforum.com/forum...ed-lights.html
post #4 of 14 Old 11-08-2015, 07:44 PM Thread Starter
RE:
Thanks "Kiss4aFrog"!
Here are the bulbs I've tried...
Gold Stars 11568302
Sylvania 1156
If everything is DC, my guess is that everything should be fine. My only qualm is if I need a resistor or not and what type...
Thanks very much for all your input so far!!!
-Scott
news82 is offline
post #5 of 14 Old 11-08-2015, 08:01 PM
liftoff1967's Avatar
Thanks (Given): 36
Thanks (Received): 45
Likes (Given): 65
Likes (Received): 94
News 82. Read thru the first couple pages of the LED Light link Kiss provided you. The rest is just model specific questions.
In a nutshell, you need a resistor to clean up the dirty voltage, which is why your blowing your LED lights right away.
I had hand warmers installed on my fathers 1982 ST1136. Like you the headlight would dim down when the hand warmers were flipped on. I installed LED's with a bridge rectifier and capacitors and made a world of difference. He is going on his second season with no issues.
Good luck. If you try to tackle this job yourself,take your time and read that LED thread a couple times, I did and it really helped me.
liftoff1967 is offline
post #6 of 14 Old 11-09-2015, 12:49 PM
I just wired one of these guys up to my older 924
lights up like a champ.
Just cut and added some waterproof connectors to the factory harness.
cvisinho is offline
post #7 of 14 Old 11-13-2015, 03:32 PM Thread Starter
Hi everyone,
Thanks very much for all the information so far. I'm going to look up the exact engine model and get back to you Kiss4aFrog. I think it's going to come down to an amperage issue here as the hand grips do get hot. My guess is that it's too much amperage for the bulb to handle if the hand grips aren't turned on. Has anyone had any luck throwing a resistor inline with the headlamp? Please let me know. Thanks very much everyone!
-Scott
news82 is offline
post #8 of 14 Old 11-15-2015, 01:47 PM Thread Starter
Hi everyone...my exact engine model is HMSK100 159433W (H)...the engine family is XTPXS.3582BF. Please let me know your thoughts. Thanks.
news82 is offline
post #9 of 14 Old 11-15-2015, 02:42 PM
Thanks (Given): 587
Likes (Given): 4352
From what I tracked down it's supposed to support 18 watts. That's the same as my 70's 1032 driftbreaker. It's capable of powering up a single 18W flood light. It's producing AC and that might be why the LEDs are popping.
I'm surprised it's able to heat the hand warmers.
post #10 of 14 Old 11-15-2015, 03:05 PM
Normex's Avatar
Likes (Received): 82
Normally some handwarmers pull 20 watts so in essence while taxing slightly the coil, it has not much left for a light bulb.
For my setup I use the AC for my hand warmers and have added a 12 volt battery to power my 27 watts Led Light. I have a battery maintainer with quick connects to recharge the battery though I have over 5 to 6 hrs of use on one charge. Just a thought and I can post pics if he wants to.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
