Ariens Cab, no fit - Snowblower Forum : Snow Blower Forums
post #1 of 24 Old 11-13-2015, 05:38 PM Thread Starter
Thanks (Given): 9
Likes (Received): 16
Ariens Cab, no fit
I have a new Deluxe 28+ with the 414cc engine and purchased the Ariens cab for it. I have tried every configuration but the front chute crank handle hits the cab cross member. Any suggestions?
2015 Ariens 28+ 414cc, drift cutters, poly skids, Ariens Cab. Debating about hand warmers.
2001 Yardworks 30/10.5 hp (sold)
1991 Yardman 24/5 hp (gave to son)
Large snow pusher for wife.
Bob z is offline
post #2 of 24 Old 11-13-2015, 06:33 PM
Likes (Received): 82
My suggestion would be to contact Ariens tech support or the dealer you bought it from.
Good Luck
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
Thanks Bob z thanked for this post
post #3 of 24 Old 11-13-2015, 07:06 PM Thread Starter
Thanks (Given): 9
I have and waiting for answers.
Bob z is offline
post #4 of 24 Old 11-14-2015, 08:27 AM
Likes (Received): 8
Sounds like you have the wrong model. There are different models for different machines. My dealer said the Ariens cab was pretty weak and sold me an Original Tractor Cab. The cab is very high quality except the width is too narrow. If all you do is walk in a straight line then it's fine, but you have zero room to move to the left or right. When it wears out I'm going to try the Ariens because it looks much wider.
Ariens Platinum 30 SHO
AriensSnowman is offline
post #5 of 24 Old 11-14-2015, 12:01 PM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
Pictures of how it's mounted and the area that's interfering might help too.
post #6 of 24 Old 11-14-2015, 01:22 PM Thread Starter
Thanks (Given): 9
Photos
Here are some photos, appreciate the help.
ID:	62689   Click image for larger version
ID:	62697   Click image for larger version
Bob z is offline
Likes SnowG liked this post
post #7 of 24 Old 11-15-2015, 07:39 PM
Thanks (Given): 51
Thanks (Received): 36
Likes (Received): 63
That crank location is definitely going to interfere with many cab frames. I think you need to find a design that has a higher or lower than usual frame cross member, or perhaps one that is mounted more forward than most, with a slit to go around the crank shaft.
I agree with the other advice to consult Ariens about the cab that fits.
SnowG is offline
post #8 of 24 Old 11-15-2015, 07:42 PM
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
Hey Bob, on a side note nice garage flooring. What type of materiel is that?
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
post #9 of 24 Old 11-16-2015, 07:34 AM
Thanks (Given): 591
Likes (Given): 4374
If you really like the cab I'd consider trying to find a way to have a chute crank made where the "cranking handle" was on the other side of the control panel if possible.
post #10 of 24 Old 11-16-2015, 03:33 PM Thread Starter
Thanks (Given): 9
Zavie, It is a vinyl floor 9 ft x 20 ft from Costco Canada for $239.00, great deal.
VersaRoll Pro 9 ft. x 20 ft. PVC Garage Flooring
Bob z is offline
