shear pin question - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 11-16-2015, 09:25 AM Thread Starter
Thanks (Given): 49
Thanks (Received): 8
Likes (Received): 7
shear pin question
I have a 1978 Ariens ST724. I have taken the front gears out of the auger two times. The first time a small stone got between the auger tine and the bucket (tear drop style). The second time I caught a mat at the door step. Neither time did the shear pins snap, thus the gears and shaft stripped out.
The auger is greased and not seized to the shaft, and I have the correct pins.
Why do they not snap, when need be? Is there a chance the shear pins are tightened too much so as the 2 grooves in the pins do not line up to the outer auger shaft?
part #510015, these are likely bought in late 70's early 80's $4.25 for 5.
I attached photos, I hope. Suggestions to what is wrong, just trying to prevent this occurring again.
Thanks ron3033
ID:	63097   Click image for larger version
ron3033 is offline
post #2 of 19 Old 11-16-2015, 10:30 AM
Thanks (Given): 33
Thanks (Received): 14
Likes (Given): 21
Likes (Received): 19
You might want to check the part no. of the pins to make sure they are the correct ones for your machine. As for tightening, the shear pins have self locking nuts so you don't need tighten them much, just a bit snug.
BullFrog is offline
Thanks ron3033 thanked for this post
post #3 of 19 Old 11-16-2015, 11:01 AM
Thanks (Given): 587
Thanks (Received): 767
Likes (Given): 4352
Likes (Received): 1734
If you posted the model and serial number we could check if the pins are correct.
Thanks Ariens Company thanked for this post
post #4 of 19 Old 11-16-2015, 12:51 PM
wdb
Thanks (Received): 23
Likes (Given): 43
Likes (Received): 69
If the grooves are important to function then yes, they had better be in the right place. It really doesn't make any sense that they did not snap under conditions serious enough to strip gears, unless those grooves are a critical component to their function and the grooves are in the wrong place. I'd be tempted to try another source for shear pins or just go see what new ones look like. (The pins for my Honda have no grooves.)
wdb is offline
post #5 of 19 Old 11-16-2015, 01:52 PM
Thanks (Given): 33
Likes (Given): 21
Yes the grooves are important as that is where they are designed to shear at a certain torque specified by the machine's manufacturer. This is why it's important to use the correct shear pin. If your shear pins are factory installed to your blower then they are likely designed to shear without the need of grooves.
BullFrog is offline
post #6 of 19 Old 11-17-2015, 08:28 AM Thread Starter
Thanks (Given): 49
Likes (Received): 7
Hello Thank You
model 924032 - 008001 7HP ST724 and I think the auger model is 924028
The pins I have are steel, I tried a magnet. No nylon insert in the nut. These are 30 years old, and #'s on the package of pins seem to be the number on the manual.
Are pins now days aluminium?
ron3033
ron3033 is offline
post #7 of 19 Old 11-17-2015, 08:53 AM
how tight were they, you should leave some slop in them. in a pinch, i have used nails believe it or not as shears pins. way better grade 5 or 8 bolts
post #8 of 19 Old 11-17-2015, 08:57 AM Thread Starter
Thanks (Given): 49
Likes (Received): 7
These Look like they may be brass. I just found on E replacement parts? Maybe steel was what was used long ago? Or are these steel that is coated?
ron3033 is offline
post #9 of 19 Old 11-17-2015, 08:59 AM Thread Starter
Thanks (Given): 49
Likes (Received): 7
Question
I remember one guy saying he only used brass brazing rods (I believe that is what it was)
ron3033 is offline
post #10 of 19 Old 11-17-2015, 09:12 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
That's not brass, it's zinc-plated steel. The plating is incredibly thin, which causes the coloration. The older ones were plated too, but the plating was thicker so it had the silver color.
ELaw is online now
Thanks ron3033, Kiss4aFrog thanked for this post
