724 ariens - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 11-16-2015, 12:46 PM Thread Starter
Thanks (Given): 121
Likes (Given): 269
Likes (Received): 6
724 ariens
I pick up a Ariens with a blow motor . I was trying to find out the Year ? Ariens 724 with a 7 h p engine . Any one have a parts list to sell ? No luck on Ebay ! Maybe I have the wrong Model # 824006 ser. 015814 5 speed and one reverse speed . Thank you. Need pulley spring and connecting rod .
eyeboltman
Eyeboltman is offline
post #2 of 5 Old 11-16-2015, 02:21 PM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3358
Likes (Received): 679
Have you looked at Scot's web site-
The Ariens 1960's and 1970's Sno-Thro info site.
I found this, and it's free-
http://apache.ariens.com/manuals/PM%2024000.pdf
Thank you Scot.
post #3 of 5 Old 11-16-2015, 02:21 PM
Thanks (Given): 72
Thanks (Received): 398
Likes (Given): 183
Likes (Received): 931
yes, you have the wrong model number.
there are three different model and serial number sets on an Ariens snowblower..so far, you have found the least useful one! (happens all the time..its the most visible tag, sitting there right in the open on the side of the scoop.)
824006 is the model number of the scoop attachment, not the model number of the snowblower..the model number of the snowblower will be on another Ariens data tag at the rear of the machine, between the wheels...thats the model number you need.
Scoop attachment number 824006 was made through most of the 1980's..
Also look for a data tag on the side of the engine, and post any numbers you find there..the Tecumseh engine serial number contains a date code that can usually pin-point the exact model year of the snowblower.
post #4 of 5 Old 11-16-2015, 06:44 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
I have Ariens Parts Available in Hudson Ma
Jackmels is online now
post #5 of 5 Old 11-17-2015, 06:46 PM Thread Starter
Thanks (Given): 121
Likes (Given): 269
Likes (Received): 6
That's guys , I did find a # on the frame that the motor sits on . It's 924048 model ser# 009002 . I will check later on the engine # it mostly rusted and hard to see it . Thank you, Eyeboltman I found some of the # on the engine H70-130210E ser 9280D or 9290D It's heavily rusted every were . Needs a connecting rod arguer bearing spring for the belt that drive the wheels . and many new bolts . Thank you. looking for parts book also for
Ariens 1980 ? 7hp. snowblower.
eyeboltman
