2 piece impeller mod? - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 11-16-2015, 01:01 PM Thread Starter
I just took my worn out toro rubber and cut it with heavy shears from harbor freight. Acquired #10 self tapping screws and noticed my ariens st1032 impeller has 6 veins. Originally I thought of using 4 pieces and space them evenly in hopes of keeping proper balance.
My question.... Has anyone used only 2? The impeller moves so incredibly fast I can't help but think it should do fine.
St1032 is offline
post #2 of 9 Old 11-16-2015, 01:20 PM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
I'm "restoring" an ST1032 and had the same thought... although I was considering going with 3 thingys instead of 2.
My biggest concern is the way the impeller is put together with the vanes being so close together, it would be very hard to get a drill to the right place without tilting it. And of course if it's tilted, it'll walk all over the place.
ELaw is offline
post #3 of 9 Old 11-16-2015, 01:51 PM Thread Starter
I removed the chute. This allowed me the room required.
St1032 is offline
post #4 of 9 Old 11-16-2015, 04:11 PM
Likes (Received): 82
2 is the absolute minimum
No really you are the one who will find out if 2 is enough. IMO I would consider at least 3 rubber mods to keep it balanced and have the best for the wet and slushy snow instances. If you choose to put 2 please report your findings here to us. Good Luck and thanks.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #5 of 9 Old 11-17-2015, 09:16 PM
I've added only 2 on my 1964 ariens with 4hp engine with the idea of putting less pressure on engine. I also didn't use rubber but old conveyor belt material. Works fine. Increased throw and haven't noticed any issues with balance.
Nconroy1 is offline
post #6 of 9 Old 11-21-2015, 05:09 PM Thread Starter
2 paddles worked great! My neighbor plugged his 2 stage machine up doing his driveway. I did my driveway and went 250ft to my other neighbors driveway and did theirs since they were out of town without any problems what so ever. What an incredible machine that ST1032!
St1032 is offline
post #7 of 9 Old 11-21-2015, 06:03 PM
Thanks (Given): 590
Likes (Given): 4366
Likes (Received): 1742
It just depends on what you call "rubber". Using bailer belt is one of higher recommended materials and it's available at a lot of farm supply stores. I get mine at FleetFarm.
I tried using tire sidewall as I have a lot of tire for weighting down my pool cover but after fighting a razor knife through it I found the thickness varies. Not a lot, but it's noticeable. You could do it but the bailer belt was too cheap not to go that way instead.
Name:	snow blower baler belt sales tag fleetfarm.jpg
ID:	63993   Click image for larger version
Name:	snow blower baler belt side view.jpg
ID:	64001   Click image for larger version
Name:	snow blower baler belt with fleetfarm tag.jpg
post #8 of 9 Old 11-21-2015, 06:07 PM
As long as your good results include wet and heavy snow also without clogging the chute. It would be a shame to almost restart from the beginning for the 3 rubber mod.
Normex is offline
post #9 of 9 Old 11-21-2015, 09:03 PM Thread Starter
Farm fleet belt
I would have driven straight to farm and fleet had I known it was available there. The toro single stage paddle didn't cut well at all so I am confident of its durabilty.
St1032 is offline
