Ariens 8524 is too slow, can I make it move faster? - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 11-17-2015, 01:00 AM Thread Starter
I have an Ariens 8524 snowblower with a Tecumseh engine. It starts and runs great. Tons of power and can pull your arms off (no slipping). The problem is, itís slow. At forward speed 6, itís about a third slower than my old Ariens 5hp (walking/drive speed). In deep snow its fine, but anything less than 8Ē its painfully slow. I already check the speed lever adjustment and it is maxed at the 6 setting, I even pulled the lower cover and the friction wheel is as far out on the disk as it can go. I bought it used a few years ago and it has always been this way. Iím considering trading it in for something faster. Is it worth buying a tach and checking the RPM? It seems like itís revving plenty high. Any suggestions to speed it up?
Mark
nagelxj is offline
post #2 of 12 Old 11-17-2015, 01:10 AM
E350's Avatar
Thanks (Given): 280
Thanks (Received): 62
Likes (Given): 159
Likes (Received): 77
Bigger tires?
E350 is offline
Likes Clint C liked this post
post #3 of 12 Old 11-18-2015, 03:13 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
a larger crank pulley for the auger belt?
db130 is online now
post #4 of 12 Old 11-18-2015, 03:45 PM
Thanks (Received): 195
Likes (Received): 816
Drop the Pan with the machine in the highest gear on the selector, the friction wheel should be all the way out to the corner of the drive plate. If not, adjust the length of the gear selector rod until it is.
Jackmels is online now
post #5 of 12 Old 11-18-2015, 03:55 PM
Thanks (Given): 589
Likes (Given): 4362
Likes (Received): 1741
I think he's already tried that.
" I even pulled the lower cover and the friction wheel is as far out on the disk as it can go."
post #6 of 12 Old 11-18-2015, 04:50 PM
Likes (Received): 483
Installing a larger pulley at the crank will give you faster speeds forward and reverse, just don't go to much on it, let say 1/2-3/4" larger.
YSHSfan is online now
post #7 of 12 Old 11-19-2015, 05:10 PM
Thanks (Received): 28
Likes (Received): 108
I am pretty confused here. What you are saying is, in 8" of snow or more, you like to use 6th gear? How is that even possible? In 4" or more of snow, I only use 1st gear. In fact I (might) only use 2nd gear to clear 3" of light snow or less, (maybe). 3rd gear is worthless and 4th gear is only used to move the machine where I want it. Totally confused here.
Kielbasa is online now
post #8 of 12 Old 11-19-2015, 05:23 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 419
Likes (Received): 664
8" of snow and 6th does sound like there is a speed issue. but 2nd for 3" also sounds like an issue if thats all the blower can handle. " most" nicely working machines like to be fed the max amt of snow they can take without bogging down. jmo
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #9 of 12 Old 11-19-2015, 10:33 PM
Thanks (Received): 112
Likes (Received): 298
Mark
Should be running at 3600 rpm +/- 100 rpm. Might want to get that checked. Seems odd that a mass produced unit from Ariens would come with a defect like that. Are you the original owner, or is it possible somebody else had their hands in it? No chance the belt is slipping on the pulley? Idler tension is good on the belt? Are both traction and auger crank pulleys the same size?
If all else is good, then either the engine is running too slow, or the traction drive pulley is too small. Have you asked Ariens about the problem?
skutflut is offline
post #10 of 12 Old 11-21-2015, 07:57 PM
Likes (Received): 14
I agree...I don't understand that. I adjusted my Platinum so it would run as slow as possible in 1st gear, because you usually rarely use more than 1st, 2nd, or 3rd (light snow) when in actual use. 4th & 5th almost never see any use and 6th is just for transporting over a longer distance.
Slinger is offline
