Warm start difficulty - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 11-20-2015, 10:48 AM Thread Starter
Have the unit in my sig - fairly new unit, less than a year old.
What is the proper way to start a warm engine on one of these (ie you ran out of gas and refueled, or just had to shut the unit off for a few min)?
With past small engines, restarting a warm engine required no choke or priming. That doesn't seem to work with this machine.
Suggestions?
Thanks!
Ariens 921037 (Deluxe 28+)
jsolo is offline
post #2 of 7 Old 11-20-2015, 11:13 AM
Likes (Given): 22
Likes (Received): 6
just give the primer a couple of pups to get the fuel going, and it will wake right up..
Ariens 921040 30 inch SHO
buddman is offline
post #3 of 7 Old 11-20-2015, 11:16 AM Thread Starter
Will give this a shot. No choke but prime it a few times right?
jsolo is offline
post #4 of 7 Old 11-20-2015, 11:20 AM
Likes (Given): 22
Likes (Received): 6
yep..should work..
buddman is offline
post #5 of 7 Old 11-21-2015, 01:43 AM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
Depends. On a few of the Tecumseh engines I've worked on, I sometimes have to return the choke to 1/2 or 3/4 choke to get it to start again. Priming it while having the choke completely off didn't get it running, but by applying some choke again, she would fire right up without priming.
GoBlowSnow is offline
Likes 43128 liked this post
post #6 of 7 Old 11-21-2015, 04:37 AM
Thanks (Received): 11
Likes (Given): 9
Likes (Received): 30
Yeah, it has always amazed me how quickly after shut down, you're going to need some choke on a 4-stroke engine. You may not really have a problem at all. In this age of EFI, people are starting to not get this....the finesse required in running stuff with carburetors........
bwright1818 is offline
Likes liftoff1967 liked this post
post #7 of 7 Old 11-21-2015, 07:46 PM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
It's not an exact science but it's always easier to give it more than to try and unflood it.
That said my personal preference is to try and pull it a couple times to see if it starts. If not, give it choke as it's the engine that's pulling the gas in.
Still no go I'll give it a pump or two on the primer which is shoving raw gas up into the throat of the carb.
I don't prime it first as most of the time choke works just fine and I don't chance having raw gas dripping out of the carb onto the machine. That's just me.
