ST824 Older--auger belt change -Grief ? - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 11-21-2015, 10:00 PM Thread Starter
Hi...Hoping someone can tell me that there's an easier way to change the auger belt on my st824...Model 924050 ...Have changed belt on my Toro 724 last year...Don't recall seeing this large gear on the wheel axel blocking the removal path...? Hope the pic shows ...Is there a simple procedure to change the belt...? Thnx in advance.
suspicionofignorance2 is offline
post #2 of 4 Old 11-21-2015, 10:21 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
are you splitting the auger half from the tractor half, even partially?
db130 is online now
post #3 of 4 Old 11-21-2015, 10:56 PM Thread Starter
Nope....Was hoping to just slip it off between pulleys...? Afraid you're going to say must separate housings? If so, will partial tilt be enuf? Never did that before on other make/models..
post #4 of 4 Old 11-22-2015, 08:55 AM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
I would first get the belt off the crank pulley, then remove the 2 9/16 bolts, the chute crank, and the halfs will separate. The Pulley brake will partially hold the belt on. It's not a big deal to do this, and when putting the halfs back together, you need to push on the Pulley brake to get the halfs to mate. Take Your time, it's not that hard to do.
Jackmels is online now
Likes gsnod liked this post
